iH 574 Gas Starting Issues
   / iH 574 Gas Starting Issues #1
Barlow96
Pa
IH 574 gas
Well decided to start my 1974 IH 574 gas this morning (been sitting idle for 2 months) and no dice. Battery is fully charged and the starter is fine ( jumped the starter and it fired right up). When I shut it off and then try to restart I get nothing. I am thinking either a bad ignition switch or bad clutch relay switch. Any other thoughts or suggestions? Also how could I test the ignition switch to determine if that's the culprit.
   / iH 574 Gas Starting Issues #2
Get out the VOM and test that switch and relay.
Thanks. I wasn't sure if there was any other components inline. Turned put to be a shot clutch relay. Now does anyone know what the voltage output for the alternator should be? I am getting 12.07 at the alternator.
I think it's bad and need to replace. I did a search and am finding many options. Any ideas of a good replacement?
   / iH 574 Gas Starting Issues #4
I have the industrial version of the 574 mine is the 2500 and i bought a universal alternator works great.Its the same Tractor just built heavier.
John Deere 5105M (A53317)
John Deere 5105M...
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A58017)
2009 FREIGHTLINER...
Kubota L4701 (A53317)
White Metal Roof Panels (A55758)
White Metal Roof...
1326 (A58374)
1326 (A58374)
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
