IH 464 PTO problem
/ IH 464 PTO problem #1
464man
IH464
When I attempt to engage the PTO on my IH 464 the lever will not lock the spool valve into place. I watched the spool valve as the lever was worked and the valve move but will not engage the PTO. I am attempting to remove the spool valve from the MCV but even with the nut fully backed out the valve will not come out. Any suggestions will be appreciated. Thanks, Mark
/ IH 464 PTO problem #2
My first thought is low/no hydraulic pressure. If the pressure is so low that it can't overcome the valve spring, there's no way it can engage the pto clutch. Check fluid, filter, and pump.
Two (2) John Deere 4000-Series Tractor Grill Guards (A65640)
Two (2) John Deere...
2007 KENWORTH T800 QUAD/A DUMP TRUCK (A59914)
2007 KENWORTH T800...
SARLO (A64557)
SARLO (A64557)
2020 International LT625 48" Sleeper (A62613)
2020 International...
2008 12ft. Alumacraft Flat Bottom Mud Boat (A64194)
2008 12ft...
Lincoln Arc Welder (A62613)
Lincoln Arc Welder...
