IH 454
/ IH 454 #1
DLTTrekkers
Paarl South Africa
My IH454 kick out of 3rd gear . I did replace all the gears on the topshaft aswell the sincros . For lateral play I added an exstra thrustwasher in the middle . Please help !
/ IH 454 #2
Sounds more like a problem with the shifting mechanism. And from the looks of the exploded view of the shifting mechanism in this exploded view Object moved There's lots of places to get some slop, and not get full dentent in a gear position.
/ IH 454 #3
Well., the link to that view didn't come through, but look at the (07-31) Drive Train, Gear Shift Mechanism, Speed Transmission in the menu at left.
/ IH 454
The rotating shiftpan has detent noches and I looked at them and milled it about 2mm in for a better detent. No luck ! On the outside is play , but that has no influence in the inside . I also check the rollpins and the shifterforks for bending and they are tru Please help ?
/ IH 454 #5
If I'm looking at it right, I'm thinking more like wear in part #'s 6, or 13. Possibly even the woodruff key #17 being work, or partially sheared. It may partially engage the gear, but depending on how much the external linkage is worn, and not push it into the full detent position. Or as mentioned wear in #'s 6 & 13 not fully engaging, even though it is in the detent notch.
Not sure how much that little finger on #6 would take, or how much wear has occured if it's been haunched on pretty good in the past.
/ IH 454
Hi DJ54
I have no idia what your talking about ......do not have the diagram.......please submitte diagram
I do get 1st and 2nd and 4th but 3rd kicks out ! Play on the outside links will effect 1st or 4th and that I do get !
/ IH 454 #7
Look back at posts 2 & 3. Click on "Object moved" (sorry it did not state it was a link to Messicks) in blue, it will take you to the IH 454 parts page. Then select "Drive Train" in the menu at left. Then scroll down to (07- 31), and left click on it. An exploded view of the shifting mechanism will appear, with the parts numbered.
/ IH 454
Thanks for that info
When spring 7 is hooked in arm 6 is detend in pan 10 And then pan 10 has no play on it . Then the sincro must be on its exact posision , but 3rd stil kicks out!
/ IH 454 #9
Is there any chance you can take the cover off, while it is engaged in 3rd gear, and see just how far the gear is engaged, without it sliding, or moving..?? If it's fully engaging, then is it a possibility the detent spring is weak, or cam roller, #8 worn enough to let it pop out of gear?
/ IH 454
Will try to take the topcover off without moving the sincro in 3rd gear and see ......Will come back later......
/ IH 454
The hole at the back of the gearbox is to small to fitt your hand through ...can not keep sincro steady in one posision . Camplate as steady as a rock in all posisions .Is threr some serial splits for the shiftpan no 10 ? I think maybe I have the wrong shiftpan in the gearbox ?
/ IH 454
OK ! I believe I solved my probleme ! Iremoeved the extra thrustwasher in the middle AND removed the bearing on the input shaft .......Remove 0.8 mm from the rearfacing of that shaft ..........measure the total play ........2.6 mm and fitt a shim of 2.6 mm between the front bearing and the front gear bringing the front gear back by 2.6 mm and fit all back and test ........
2018 Mitsubishi Mirage Hatchback (A64557)
2018 Mitsubishi...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
2022 SANY SY5OU EXCAVATOR (A63276)
2022 SANY SY5OU...
1995 Ford LT9000 Tri-Axle Dump Truck (A64556)
1995 Ford LT9000...
John Deere 544K Articulated Wheel Loader (A64553)
John Deere 544K...
