IH 454
/ IH 454
The hole at the back of the gearbox is to small to fitt your hand through ...can not keep sincro steady in one posision . Camplate as steady as a rock in all posisions .Is threr some serial splits for the shiftpan no 10 ? I think maybe I have the wrong shiftpan in the gearbox ?
/ IH 454
OK ! I believe I solved my probleme ! Iremoeved the extra thrustwasher in the middle AND removed the bearing on the input shaft .......Remove 0.8 mm from the rearfacing of that shaft ..........measure the total play ........2.6 mm and fitt a shim of 2.6 mm between the front bearing and the front gear bringing the front gear back by 2.6 mm and fit all back and test ........
SKIDDED FRAC TANK (A60736)
SKIDDED FRAC TANK...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
24in excavator tooth bucket (A61307)
24in excavator...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
