IH 384 Starting Problem
/ IH 384 Starting Problem #1
Rockin' G Ranch
Point Blank, TX
Kubota L4740 HST with FEL
I have a diesel IH 384 that has gotten progressively harder to start. Once it finally starts it runs good and will start again easily. If it sits overnight it will just crank and not even sputter for a long time and smoke a little if any. Smoke is also grey/white. This happens in winter and summer. I had the glow plugs checked and was told they were good.
Could it be a fuel problem or fuel line leak, etc. Any other ideas???? Thanks.
/ IH 384 Starting Problem #2
I think I'd bite the bullet and have the compression checked.
soundguy
/ IH 384 Starting Problem #4
mechanic in a can?
If you have a real engine problem... it won't help much if any. ( won't hurt.. )
soundguy
/ IH 384 Starting Problem #5
G'day try bleeding the fuel system before you try and start it in the morning you may be getting air in the system o/night if this doesn't help then possibly have injectors tested and while they are out as soundguy said have compression checked.
Jon
/ IH 384 Starting Problem #6
I would first check the battery, the cables and the starter. If diesel engines don't crank over FAST they will be hard to start. Just because the starter turns the engine over, it does not mean it is "good".
I chased a hard start problem on my 88 7.3 engine for a while, the solution was a new starter, it was like night and day.
Wayne
/ IH 384 Starting Problem #7
I would check the glow plug relay and make sure it is getting voltage to the glow plugs. The reason that I think this is it will start easy after it is warmed up. I agree with the air in the fuel line as well it can give the same grief.
I would first check the battery....
Wayne
Wayne, you are right on! I went to work at the ranch this weekend. The tractor had been shut off for 3 weeks. I did not even try to start it using the tractor battery. I used very heavy duty jumper cables from the tractor battery to my diesel truck battery. There was a noticeable increase in the starter RPM and the tractor started right up.
I installed a battery tender on the tractor battery to hopefully keep it fully charged while not in use. I guess the worst case scenario is to jump it with my truck the first time.
Thanks for the good advise!
/ IH 384 Starting Problem #9
if it's a battery with a low cell.. that tender may not help it.. might need to load and specific gravity test the battery.
soundguy
/ IH 384 Starting Problem #10
If you have confirmed that you are getting good cranking speed (voltage and amps) then I'd look at the glow plugs. The BD154 has it's glow plugs run is series, so you need to have all of them working and there is a resistor the shows when the glow plugs are warm enough to start which can burn out and cause the glow plugs to not get hot.
There are some ways to convert the BD154 to use a nomal glow plug this thread talks about them.
HCVC Vintage Truck Forum - international 414
The BD154 glowpugs are the same as some Mercedes plugs and the are better glow plugs for the Mercedes.
http://www.peachparts.com/shopforum/showthread.php?t=151959
May Industry Co., Ltd.-GLOW PLUGS
Mercedes glowplug conversion - Google Search
I plan to convert my 424 that has a BD-154 to a better glow plug system.
Carey
2022 BOBCAT T76 PLATINUM R-SERIES SKID STEER (A65053)
2022 BOBCAT T76...
2009 International 4300V 24ft. Cab and Chassis Truck (A64194)
2009 International...
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A64553)
2019 Toro...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
