IH 350u Questions
/ IH 350u Questions #1
dannyw
ih350u
I'm a new owner of a ih350u and I don't know where to add transmission fluid. Can someone help. Also I am replacing the PTO outer seal and the new one is only half the thickness of the old one, is this normal?
/ IH 350u Questions #2
Suggest you "search" for a better forum..ie. one that deals specifically with "yesterday's tractors"...How old is your 350? The IH 50's/60's stuff used separate hyd and trans lubes/fluids. The trans drains (may be two of them) will be under the diff. and under the trans....for the hyd. "block", follow the hyd lines from the pump (usually found right under the distributor), back to the block...there should be a large "bolt" head (about 1 1/16") on the opposite side of block..that's where the fill hold is...trans fluid should be 80w-90 gear oil...hyd fluid can be 20w hyd fluid. BobG in VA
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2007 CM TRAILER 18' T/A ENCLOSED TRAILER (A65643)
2007 CM TRAILER...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
2009 International 4300 Digger Derrick (A62613)
2009 International...
