IH 3414 Battery problem
/ IH 3414 Battery problem #1
pddtovar
CA
IH 3414
I bought a IH 3414. It had been sitting and the battery wouldn't hold a charge. I replaced the battery thinking the red cable was positive. Unfortunately, it had been replaced too. The red one was negative. You can guess what happened. Did I blow the alternator? Where should I go from here? Any ideas?:confused:
/ IH 3414 Battery problem #2
G'day there is every chance you have blown a diode/s in the alt but you never know your luck hook it up start it and grab the multi meter and see if it charges you might be lucky :)
Jon
/ IH 3414 Battery problem #3
Going back to my diode bridge theory, I would say the doides are history. With the battery reversed, you have two forward biased diodes across the battery so it is virtually short circuited by the diodes and hence will draw large current (for VERY short time) until the diodes burn out.:(
Cityfarma
/ IH 3414 Battery problem #4
TRY A VOLT METER AN SEE IF ALT IS PUTING OUT BEFORE YOU REPLACE IT I KNOW SOMEONE THAT DID THE SAME AN GOT LUCKY IT DID NOT HURT THE ALT
2018 FORD TRANSIT KUV (A67714)
2018 FORD TRANSIT...
2021 JOHN DEERE 304L WHEEL LOADER (A65056)
2021 JOHN DEERE...
2015 Freightliner M2 106 Hawk H-1150TL Forestry Grapple Truck (A66736)
2015 Freightliner...
KOMATSU D51PXI-24 CRAWLER DOZER (A65053)
KOMATSU D51PXI-24...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
