IH 3414 Battery problem
/ IH 3414 Battery problem #1
pddtovar
CA
IH 3414
I bought a IH 3414. It had been sitting and the battery wouldn't hold a charge. I replaced the battery thinking the red cable was positive. Unfortunately, it had been replaced too. The red one was negative. You can guess what happened. Did I blow the alternator? Where should I go from here? Any ideas?:confused:
/ IH 3414 Battery problem #2
G'day there is every chance you have blown a diode/s in the alt but you never know your luck hook it up start it and grab the multi meter and see if it charges you might be lucky :)
Jon
/ IH 3414 Battery problem #3
Going back to my diode bridge theory, I would say the doides are history. With the battery reversed, you have two forward biased diodes across the battery so it is virtually short circuited by the diodes and hence will draw large current (for VERY short time) until the diodes burn out.:(
Cityfarma
/ IH 3414 Battery problem #4
TRY A VOLT METER AN SEE IF ALT IS PUTING OUT BEFORE YOU REPLACE IT I KNOW SOMEONE THAT DID THE SAME AN GOT LUCKY IT DID NOT HURT THE ALT
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
2011 SHBO MANIFOLD TRAILER (A67714)
2011 SHBO MANIFOLD...
2021 John Deere 4044M (A64126)
2021 John Deere...
2017 Blue Bird 71 PAX School Bus (A66736)
2017 Blue Bird 71...
2009 POLAR TANK TRAILER (A67714)
2009 POLAR TANK...
