Ignition switch issue 3038 3032 Common problem? Is there a fix? or replace?
/ Ignition switch issue 3038 3032 Common problem? Is there a fix? or replace? #1
johneic
Paducah (West) Kentucky
JD 3038e, Bolens-Iseki G174 2 Cylinder (early), Kubota B7200E 2WD belly mower
I have a first year 3038, so 6-7 years old, about 580 hours of light use, The ignition switch collar is loose, key is hard to turn and I have to push in hard to get it to turn. I am afraid I might break off the key in it.
Is there a repair for this or replace it with a new factory unit? or an aftermarket switch?
John
/ Ignition switch issue 3038 3032 Common problem? Is there a fix? or replace? #2
New ignition switch.. $45 part LVU29433
Pic of what you have that is loose would maybe help with better solution.
I thought a video might be better, one minute long,
YouTube
/ Ignition switch issue 3038 3032 Common problem? Is there a fix? or replace? #4
link not working for me.
/ Ignition switch issue 3038 3032 Common problem? Is there a fix? or replace? #5
Do you keep the JD key on a heavy keychain? :confused:
I have never seen an ignition switch that would not fail from an excess number of keys hanging on the switch.
This pic shows the MAXIMUM amount of weight that I will put on a JD switch,,,
This tractor has 3X the number of hours as the OP stated.
2023 Unused Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
2023 Unused Del...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
2012 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A66736)
2012 Freightliner...
Year: 2003 Make: Ford Model: Mustang Vehicle Type: Passenger Car Mileage: 151,297mi Plate: Body (A66738)
Year: 2003 Make...
