Ignition switch issue 3038 3032 Common problem? Is there a fix? or replace?
   / Ignition switch issue 3038 3032 Common problem? Is there a fix? or replace? #1
johneic
Paducah (West) Kentucky
JD 3038e, Bolens-Iseki G174 2 Cylinder (early), Kubota B7200E 2WD belly mower
I have a first year 3038, so 6-7 years old, about 580 hours of light use, The ignition switch collar is loose, key is hard to turn and I have to push in hard to get it to turn. I am afraid I might break off the key in it.
Is there a repair for this or replace it with a new factory unit? or an aftermarket switch?
John
   / Ignition switch issue 3038 3032 Common problem? Is there a fix? or replace? #2
New ignition switch.. $45 part LVU29433
Pic of what you have that is loose would maybe help with better solution.
I thought a video might be better, one minute long,
YouTube
   / Ignition switch issue 3038 3032 Common problem? Is there a fix? or replace? #4
link not working for me.
   / Ignition switch issue 3038 3032 Common problem? Is there a fix? or replace? #5
Do you keep the JD key on a heavy keychain? :confused:
I have never seen an ignition switch that would not fail from an excess number of keys hanging on the switch.
This pic shows the MAXIMUM amount of weight that I will put on a JD switch,,,
This tractor has 3X the number of hours as the OP stated.
2005 Peterbilt 387 with Wet Kit (A56435)
2005 Peterbilt 387...
John Deere 1770NT (A53317)
John Deere 1770NT...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
2024 Deere 335P (A53317)
2024 Deere 335P...
2024 Deere 35P (A53317)
2024 Deere 35P...
2014 Toyota Corolla Sedan (A55853)
2014 Toyota...
