If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #241
where do i see the engine code?
   / If you have Toolcat questions, ask them here... #242
No I did not see a plate with the serial number, but I did get the rear steering to work, I traced the wires to the solenoid a, and a mouse had a nest in there and chewed the wire!
So on to my next problem, my oil pan leaks at the bottom corner and bobcat wants 340.00 for the oil pan plus 30 for the gasket.
Does anyone know if I can get the oil pan from kubota? It is a kubota engine isn't it?
Or if someone has a part number for it, the dealer needs the serial number from it to order the pan
https://parts-barn.com/index.php/02-03-series-take-off-oil-pan-kubota.html
   / If you have Toolcat questions, ask them here... #244
can i get the oil pan off without lifting the engine?
it looks like part of the frame covers the back bolts. any ideas?
   / If you have Toolcat questions, ask them here... #245
there's nothing in the way. mine is fully accessible.
   / If you have Toolcat questions, ask them here... #246
It looks like part of the frame blocks the bolts on the back of the oil pan
   / If you have Toolcat questions, ask them here... #247
now yet another problem, the heater blower motor will run for around 30 sec then shut off, comes back on 20-30 sec later then shuts off
it does this non stop, doesnt matter if its on low speed fan or high or hot or cold
sometimes its off for 5 sec then back on. sportic
   / If you have Toolcat questions, ask them here... #248
Loose connection somewhere. Could be @ switch, fan, relay, fuse. Inspect each and try wiggling the wires, with fan running, close to them to see if you can make it shut off.
   / If you have Toolcat questions, ask them here... #249
Finally repaired my 5600 after a lot of head banging on the wall. The starter and fuel shut off wouldn't work. Found that it was a wire between the ignition switch and the controller. Got that new controller for nothing SSdoxie. So it is for sale. Then the boom got lazy and the toolcat wouldn't move at all. Realized that the charge pump wasn't giving any pressure. Found out a piece was missing on the charge relief valve. After all that fun, i took care of that fwd and aft movement that wasn't present. One the the wire on the fwd reverse coil was broken. Now waiting for parts to arrive to finish all those snag. So one coil at 400$ and the relief valve at 350$. Thank you Bobcat for those cheap prices.
   / If you have Toolcat questions, ask them here... #250
Hi guys I'm new here not sure if in rite place I'm having a major issue with my tool cat 5600 . machine won't start i thought it was battery so i bought a new battery , now i have power but when i go to start i hear a clunk and the motor doesn't turn i assumed it was starter so i bought a new starter tried again still doing same thing i hear a loud clunk in the starter but it doesn't even turn over not even sure it extends the teeth . i have 12 volt power @ starter . Help I'm not sure what else it can be ? is there some kind of ignition switch or something I'm bypassing over thinking maybe any help would be greatly appreciated Thanks in advance Jay
2008 Caterpillar 305C CR (A53317)
2008 Caterpillar...
2021 Deere 325G (A53317)
2021 Deere 325G...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2018 Autocar ACX Xpeditor T/A EZ-Pack Hercules 40 Yard Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
1998 WABASH TL Wabash National Corporation (A56858)
1998 WABASH TL...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
