If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #151
How do you raise the bed of a toolcat 5600 when the power is dead...you can't get to the battery to charge it and you can't raise the bed without the charge.....HELP!!!
   / If you have Toolcat questions, ask them here... #152
See : http://www.tractorbynet.com/forums/toolcat/225819-how-replace-dead-battery-5600d-2.html
Also, I looked at Toolcat and it appears you can remove the plastic panel behind the cab and below the bed to get access to the battery. I have not done this myself, but it looks like it can be done.
DEWFPO
   / If you have Toolcat questions, ask them here... #153
See the post in this forum dated 11/20/2011 titled "How To Replace A Dead Battery 5600d".
   / If you have Toolcat questions, ask them here... #154
Dealer says I need new turbo on 2008 5600, anyone know of a place in Ontario or Quebec who rebuilds turbos ?
   / If you have Toolcat questions, ask them here... #155
I'd also be happy with a contact for a good quality aftermarket turbo.
I just can't accept $3750 + labour at the dealer.
I'm at the point where I'll park it and use it for parts for the other two.
Have a boatload of snow so far this season with another 4" forecast in two days.
Plz help.
   / If you have Toolcat questions, ask them here... #156
What is the hyd. oil type in bobcat 2300 and quantity?
   / If you have Toolcat questions, ask them here... #157
If my information is correct the turbo on my 2009 5600D is a Mitsubishi MHI TD03-7G (same as S160 skid steer?)
P/N : 49131-02020 (replaces 49131-02010)
Kubota P/N : 1G622-17013
oil cooled
Perhaps you can Google search it and see if you can find it cheaper, these should be fairly common on a variety of pieces of equipment.
DEWFPO
   / If you have Toolcat questions, ask them here... #158
Hi UFM82, I replace the axle seals on my 04 Toolcat, I thought I read that 5w30 could be used in the rearend, dores tis sound correct?
   / If you have Toolcat questions, ask them here... #159
oil cooled
DEWFPO
Yup, was able to find on internet out of China, will know more when they, yes I ordered two, arrive.
New problem is the '05 Toolcat. Runs like a champ for 15 minutes then the hand throttle has no affect on rpm, machine limps along in idle.
We are thinking fuel pump ? sensor ?
But we were able to fit the turbo from the '05 on the '08 and now the '08 is good to go again, ran it for 6 hours today blowing back snowbanks without any issues.
Does anyone know of any diagnostic program, ideally on Ipad, that will communicate with toolcats and skidsteers ?
   / If you have Toolcat questions, ask them here... #160
The differential is Limited Slip so a Limited Slip fluid should be used. Using engine oil or an ISO hydraulic fluid could affect braking (wet disc brakes) and/or Limited Slip function.
1605 (A57192)
1605 (A57192)
Unused 2024 AGT H15 Mini Excavator (A59228)
Unused 2024 AGT...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
2012 John Deere 6170R (A57148)
2012 John Deere...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
