If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #141
I just got off the phone with my dealership in reference to my 2009 Toolcat 5600D's traction issue, the technician told me that "work mode" would significantly increase the traction on my machine and that combining that with extra weight in the box should allow me to navigate through muddy areas with ease. He also recommended taller and narrower tires to cut down on float.... Not sure if he was just shining me on or if these suggestions will really dramatically improve my machines' traction, but he insisted that "work mode" transfers low end power to the wheels! Anyone know for sure if this is the case or not?
   / If you have Toolcat questions, ask them here... #142
Does anybody know where the switches are for the steering indicators? My rear indicators is not lighting up..
Thanks
The sensor might be shot, or just a blown bulb. If you don't want to go through the expense of a service visit, you might just do it by sight. Just look at the rear tires and when they look straight, you're good to go. There's a lot of play in the indicator anyway. I can move the wheel several inches without the light going out.
   / If you have Toolcat questions, ask them here... #143
Where are they located? I may have both a lamp out and a sensor gone but I can't locate it.
   / If you have Toolcat questions, ask them here... #144
Sorry I may have jacked this thread. My guess is your problem.is a traction issue. If the wheels are spinning and the machine is sinking, How is more power going to help?
   / If you have Toolcat questions, ask them here... #145
Work shuts the horse power management off and requires pushing on the pedal a little more before drive starts to engage. Explanation HP management example - if driving in normal mode @ full pedal stroke and you start to go up an incline, the hydrostatic drive will automatically back off some to keep engine RPM up. Work mode just shuts this feature off so driver has full control and changes the ratio of pump stroke/pedal movement.
   / If you have Toolcat questions, ask them here... #146
Wheel position sensors are located in the top of the king pin at right front and left rear on straight axle models (pre-D series). D series they are located on the front & rear steering cylinders.
   / If you have Toolcat questions, ask them here... #147
Thanks for the relpy.. I'll check it out
__________
Alan
   / If you have Toolcat questions, ask them here... #148
Hi Penderie..
I have the user manual for you..And i am sure you can find the switches in the steering indicators..
Operating
The product review is given with each of its parts identified..
   / If you have Toolcat questions, ask them here... #149
I posted recently on by 256 hour 2009 toolcat 5600 having intermittent swashplate errors. Dealer after over a week said it needed a new swashplate sensor. Any ideas on how much it should cost to replace the swashplate sensor (include cost of swashplate sensor) Thanks swein:confused:
   / If you have Toolcat questions, ask them here... #150
I have a 2011 Bobcat toolcat. I start to drive it and then locks up on me no fwd movement plus I dont have reverse function. displays shows 50-59 now showing 50-54. once i restart vehicle it runs for a while and locks up again. talk to dealer they said swashplate sensors could be bad? Where is this swashplate and sensors located???
   / If you have Toolcat questions, ask them here... #151
How do you raise the bed of a toolcat 5600 when the power is dead...you can't get to the battery to charge it and you can't raise the bed without the charge.....HELP!!!
   / If you have Toolcat questions, ask them here... #152
See : http://www.tractorbynet.com/forums/toolcat/225819-how-replace-dead-battery-5600d-2.html
Also, I looked at Toolcat and it appears you can remove the plastic panel behind the cab and below the bed to get access to the battery. I have not done this myself, but it looks like it can be done.
DEWFPO
   / If you have Toolcat questions, ask them here... #153
See the post in this forum dated 11/20/2011 titled "How To Replace A Dead Battery 5600d".
   / If you have Toolcat questions, ask them here... #154
Dealer says I need new turbo on 2008 5600, anyone know of a place in Ontario or Quebec who rebuilds turbos ?
   / If you have Toolcat questions, ask them here... #155
I'd also be happy with a contact for a good quality aftermarket turbo.
I just can't accept $3750 + labour at the dealer.
I'm at the point where I'll park it and use it for parts for the other two.
Have a boatload of snow so far this season with another 4" forecast in two days.
Plz help.
   / If you have Toolcat questions, ask them here... #156
What is the hyd. oil type in bobcat 2300 and quantity?
   / If you have Toolcat questions, ask them here... #157
If my information is correct the turbo on my 2009 5600D is a Mitsubishi MHI TD03-7G (same as S160 skid steer?)
P/N : 49131-02020 (replaces 49131-02010)
Kubota P/N : 1G622-17013
oil cooled
Perhaps you can Google search it and see if you can find it cheaper, these should be fairly common on a variety of pieces of equipment.
DEWFPO
   / If you have Toolcat questions, ask them here... #158
Hi UFM82, I replace the axle seals on my 04 Toolcat, I thought I read that 5w30 could be used in the rearend, dores tis sound correct?
   / If you have Toolcat questions, ask them here... #159
oil cooled
DEWFPO
Yup, was able to find on internet out of China, will know more when they, yes I ordered two, arrive.
New problem is the '05 Toolcat. Runs like a champ for 15 minutes then the hand throttle has no affect on rpm, machine limps along in idle.
We are thinking fuel pump ? sensor ?
But we were able to fit the turbo from the '05 on the '08 and now the '08 is good to go again, ran it for 6 hours today blowing back snowbanks without any issues.
Does anyone know of any diagnostic program, ideally on Ipad, that will communicate with toolcats and skidsteers ?
   / If you have Toolcat questions, ask them here... #160
The differential is Limited Slip so a Limited Slip fluid should be used. Using engine oil or an ISO hydraulic fluid could affect braking (wet disc brakes) and/or Limited Slip function.
2023 Chevrolet Tahoe SUV (A59231)
2023 Chevrolet...
JOHN DEERE 6430 PREMIUM TRACTOR (A60430)
JOHN DEERE 6430...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2001 John Deere M665 60in Zero Turn Commercial Mower (A59228)
2001 John Deere...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
