If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #151
How do you raise the bed of a toolcat 5600 when the power is dead...you can't get to the battery to charge it and you can't raise the bed without the charge.....HELP!!!
   / If you have Toolcat questions, ask them here... #152
See : http://www.tractorbynet.com/forums/toolcat/225819-how-replace-dead-battery-5600d-2.html
Also, I looked at Toolcat and it appears you can remove the plastic panel behind the cab and below the bed to get access to the battery. I have not done this myself, but it looks like it can be done.
DEWFPO
   / If you have Toolcat questions, ask them here... #153
See the post in this forum dated 11/20/2011 titled "How To Replace A Dead Battery 5600d".
   / If you have Toolcat questions, ask them here... #154
Dealer says I need new turbo on 2008 5600, anyone know of a place in Ontario or Quebec who rebuilds turbos ?
   / If you have Toolcat questions, ask them here... #155
I'd also be happy with a contact for a good quality aftermarket turbo.
I just can't accept $3750 + labour at the dealer.
I'm at the point where I'll park it and use it for parts for the other two.
Have a boatload of snow so far this season with another 4" forecast in two days.
Plz help.
   / If you have Toolcat questions, ask them here... #156
What is the hyd. oil type in bobcat 2300 and quantity?
   / If you have Toolcat questions, ask them here... #157
If my information is correct the turbo on my 2009 5600D is a Mitsubishi MHI TD03-7G (same as S160 skid steer?)
P/N : 49131-02020 (replaces 49131-02010)
Kubota P/N : 1G622-17013
oil cooled
Perhaps you can Google search it and see if you can find it cheaper, these should be fairly common on a variety of pieces of equipment.
DEWFPO
   / If you have Toolcat questions, ask them here... #158
Hi UFM82, I replace the axle seals on my 04 Toolcat, I thought I read that 5w30 could be used in the rearend, dores tis sound correct?
   / If you have Toolcat questions, ask them here... #159
oil cooled
DEWFPO
Yup, was able to find on internet out of China, will know more when they, yes I ordered two, arrive.
New problem is the '05 Toolcat. Runs like a champ for 15 minutes then the hand throttle has no affect on rpm, machine limps along in idle.
We are thinking fuel pump ? sensor ?
But we were able to fit the turbo from the '05 on the '08 and now the '08 is good to go again, ran it for 6 hours today blowing back snowbanks without any issues.
Does anyone know of any diagnostic program, ideally on Ipad, that will communicate with toolcats and skidsteers ?
   / If you have Toolcat questions, ask them here... #160
The differential is Limited Slip so a Limited Slip fluid should be used. Using engine oil or an ISO hydraulic fluid could affect braking (wet disc brakes) and/or Limited Slip function.
2017 Chevrolet Tahoe, 179,380 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2017 Chevrolet...
2004 Ford F-150 Ext. Cab Pickup Truck (A59230)
2004 Ford F-150...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2001 BOBCAT 773 SKID STEER (A60429)
2001 BOBCAT 773...
PARTS ONLY - Has Title - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - Has...
