If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #701
Use a slide hammer type seal puller like this one. Drill a small hole in the seal and screw in a metal screw. Use the SH attachment that hooks under the screw head (second from right) and carefully pull the seal.
Slide Hammer and Puller Set, 14 Piece
   / If you have Toolcat questions, ask them here... #702
Thank you ruffdog, i'll let you know how it turns out.
   / If you have Toolcat questions, ask them here... #703
in the past I have used a self drill screw to thread into the seal, usually 2 opposite or 3 evenly spaced and used a pry bar to ease it out, seems on older machines the seals were way better, these new ones are tin and wear faster
   / If you have Toolcat questions, ask them here... #704
How do I clear the service reminder on my 2021 Toolcat (with a keyless start).
I cannot find instructions how to do it in the service manual.
Are these instructions correct for my machine?
   / If you have Toolcat questions, ask them here... #705
My service manual for my 2017 G series 5610 (section 60-190 Maintenance clock) agrees with the post above with minor changes:
Key OFF (press OFF for keyless), Press the HOURS button to turn the panel ON, Press and hold both HOURS and AUX HYDRAULICS till panel displays reset.
   / If you have Toolcat questions, ask them here... #706
Thanks. I’ll try to use your page reference to find it my manual as well.
   / If you have Toolcat questions, ask them here... #707
Have a 2007 with 2 codes:
50-73
50-75
Anyone have a code list?
   / If you have Toolcat questions, ask them here... #708
Just replaced the controller on a 5600 Toolcat and now the glow plug and aux hydraulics lights are flashing, the temp gauge is pinned to max...
It starts ok, but won't go into gear or anything else. Lift tilt and traction functions disabled even with arm rest down.
What's going on? Is there a reset procedure for a new controller?
Any help appreciated!!
   / If you have Toolcat questions, ask them here... #709
What was the reason for the new controller? Does it have keyless start? Did you double check the connections for loose,broken,bent pins?
   / If you have Toolcat questions, ask them here... #710
50-73
50-75
50-73 = Throttle Sensor Ch A Out Of Range High
50-75 = Throttle Sensor Ch B Out Of Range High
2005 Ford Freestyle Multipurpose Vehicle (MPV), VIN # 1FMZK01175GA19616 (A57453)
2005 Ford...
Electric Horseless Carriage (A57453)
Electric Horseless...
John Deere 1025R (A53317)
John Deere 1025R...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
