If there are aliens, what will they look like?
   / If there are aliens, what will they look like? #241
"I get that your angry as I went through the same when I went down this rabbit hole. It's OK."
lol angry. If I was going to be angry about anything in regard to yourself, it was writing a reply missing the direction you were headed ... if only I'd arrived on the thread a few minutes later and noted your follow up reply ... but I write considerably more - a lot of stuff is discarded because I think probably isn't the right tone for a suitable reply.
The only rabbit hole I'm in is the consequences of replying to someone who's fishing for more attention they'd ordinarily get.
It's actually all rather sad to me, reading your education experience, if you sat classes and didn't come to understand, yeah I saw a lot of that in people who went into various science type field as well, memory gets them through the exams, but very little real understanding of it. It's a pity, once there's enough of them, those running science using good solid scientific principals, approach and not tiding observations into any bias, and getting way different take - are labelled controversial or trouble makers.
Grasping the nuances you apparently are struggling with - gravity for example, only required doing a bit of reading of the basics, and noting general observations, like those from a century or so ago, that if one really wanted to, could check themselves. These days I think a precise plumb bob is easily had or at least of all, borrowed. Same sort of thing for the flat earthers, there's simple observations made so very easy with modern mobile phones and ability to communicate instantly with people hundreds of miles away ... but people like me know they are more likely to have a superiority complex and it's unkind for me to taunt them by calling them chicken 'it for not enacting something that actually was a bit of a challenge a couple thousand years ago.
   / If there are aliens, what will they look like? #242
Sounds like the only person with a superiority complex is yourself. You can speak down to me all you want. I've encountered worse.
If you can't question "science" then it is nothing more than a cult. If you want to PM me to discuss this further and rebuff my assertions I am open. Just remember I was where you were about 8 yrs ago so I understand the common misconceptions we were indoctrinated with, such as "gravity".
   / If there are aliens, what will they look like? #243
You need to look up what a superiority complex is, not every flat earther is that way.
Given the little that you know, of course I'm speaking down to you, how can I not, but there's also a degree of sadness and pity for you. You are seemingly totally unaware that you come across little different to me than to the number of poor sods I've bumped into while stretching my legs at night, while they've been in a drug induced stupor, half lost trying to find their way back to their mate / supplier and all the while wanting to tell me about their latest revelations. On top of that, there's your evasive strategies / tactics that have obviously been fine tuned over the years on the job, if engineering has been your field of work - then again I've met a foreman responsible for implementing design that couldn't even read a simple plan / map, what a cucumber.
I'm not stopping you from investigating gravity, look it up on the net for extra clues, mind any article will probably use a different word to plumb bob, I'm just generalising.
Like I said a few replies back, if you want to talk cats, I could probably find you a lovely tarot card reader ...
Questioning btw is fine, but silliness is defined by expecting a different result for the same action that an almost endless number of times before gave the same answer.
   / If there are aliens, what will they look like? #244
Wow you are angry. 🤠
Science that can't be questioned is a cult. You wouldn't be a scientologist?
I would welcome you to answer a simple physics question: how can a pressures system (atmosphere) exist next to a vaccum (space) without a barrier?
   / If there are aliens, what will they look like? #245
Nah you might think so, but it's just the way I write if anything.
You've done a good job not actually answering any thing asked apart from going around in circles. The atmosphere query was already answered, it's called gravity. I see little point for me to waste any number of minutes on a long reply that you'll look at and then proceed into the next side step. Do you realise the earth loses some of the lighter gases? Have you wondered why Mars doesn't have much of one, and yet Venus has quite a thick atmosphere despite being so hot?
Well it's very late here, so I'm off to bed. Enjoy your day and maybe do some reading.
   / If there are aliens, what will they look like? #246
So if gravity is the answer could you replicate a rotating sphere with water adhering to its surface (without falling off) in a chamber that has pressure and vacuum simultaneously, since gravity acts on all objects?
   / If there are aliens, what will they look like? #247
   / If there are aliens, what will they look like? #248
Ummm....actually, like I said before, it is the magnetic field that protects the atmosphere. Mars doesn't have a mag field so they lost the atmosphere.
https://eos.org/research-spotlights/how-marss-magnetic-field-let-its-atmosphere-slip-away
That would make more sense than a mysterious force called gravity (that evidently has a mind of its own to read the interaction between pressures and vacuum) that can be explained by relative density.
Wikepedia: Earth's magnetic field, also known as the geomagnetic field, is the magnetic field that extends from earth's interior out into space.
The problem I have with this explanation is that the deepest hole ever drilled was less than 10 miles. The earth is supposedly 7,915 mile in diameter so how does one know what the earth is composed of?
Another interesting question I've had is concerning the supposed Gravitational constant which is the magnitude of the gravitational attractive force between two bodies to their masses and the distance between them. Since the moon is supposedly much smaller than the earth how does the moon create tidal forces (waves) on the earth? And why wouldn't the earth suck the moon right into itself? Why does the earth supposedly rotate and moon doesn't? A lot of answers that require a large leap of FAITH.
   / If there are aliens, what will they look like? #249
One of the assumptions we make about ETs, might also be a logical misdirection. In the sense that intelligent life HAS to be yoked to a planet. A sufficiently advanced race might have abandoned the idea of needing any sort of planet. They could be entirely space based and self sufficient. And the only encounters we would have would be with their mechanical resource extraction systems. We don't meet the aliens, we just encounter their robotic proxies, that may or may not care if there is "intelligent" life on the mining zone. :) And a wilder theory is that the aliens might not have had a deadman switch, if for some reason they all died on their mothership, the system would keep going. It had no reason to stop.
   / If there are aliens, what will they look like? #250
Interesting and well thought out!
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
2021 Bobcat T66 Skid Steer (A57453)
2021 Bobcat T66...
DEVELON DL250-7 WHEEL LOADER (A59823)
DEVELON DL250-7...
PARTS ONLY - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - 2023...
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
2012 Freightliner Cascadia (A56436)
2012 Freightliner...
