sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,306
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
Ah.... wha...That would make more sense than a mysterious force called gravity (that evidently has a mind of its own to read the interaction between pressures and vacuum) that can be explained by relative density.
Wikepedia: Earth's magnetic field, also known as the geomagnetic field, is the magnetic field that extends from earth's interior out into space.
The problem I have with this explanation is that the deepest hole ever drilled was less than 10 miles. The earth is supposedly 7,915 mile in diameter so how does one know what the earth is composed of?
Another interesting question I've had is concerning the supposed Gravitational constant which is the magnitude of the gravitational attractive force between two bodies to their masses and the distance between them. Since the moon is supposedly much smaller than the earth how does the moon create tidal forces (waves) on the earth? And why wouldn't the earth suck the moon right into itself? Why does the earth supposedly rotate and moon doesn't? A lot of answers that require a large leap of FAITH.
The sun will come up in the morning and again in 24 hours, do to rotation of earth once every 24 hours.
And in honor of your post I want to repost short video by Carl SaganGravity is something that we have not yet figured out. We know how it works, but we don't know why it works. We can calculate to near perfect precision how to use it. This is science. Its useful. The why, still eludes us as to what gravity is. It may take 20 years to figure it out, or it may take 1,000 years to figure it out. The thing is, science mostly doesn't stop trying to figure out things. Other belief systems just say... its this thing. Period.. And one may adopt those rules and live a perfectly happy life. Yet being a scientist, one is always questioning, always in a sense of wonderment of what we don't know. I've chosen that life over superstition. It is at times painful, as there are few social structures to support scientists, still, after a thousand of years of theism, those communities are still there and don't wish to change even though the technology available has changed - radically.
This is one reason why we have wars.
If we ever did have aliens arrive on Earth as something recognizable, it would politically/religiously tear this planet apart. And being smarter than us, they would just let it happen or maybe even instigate a few things to their advantage.
It might be a usual thing to them. Been there, done that, and no more of a second thought than us setting ant traps.![]()
The Pale Blue Dot
his last statement at 3:06
empathy and hope.
