Idle tractor or turn off?
   / Idle tractor or turn off? #11
I'll let it idle for maybe 5 minutes or so...if longer then that, I shut it down. Winter...probably longer idling to keep the engine and cab (hot water heater) warm.
BTW, when I write "idle", it's idling at 1500 RPM...I never idle the engine at less then 1500 RPM.
   / Idle tractor or turn off? #12
Wet stacking and degrading the lubrication and cylinder-piston sealing of an unloaded, cold running engine is the biggest concern I know of. The emissions stuff is newer than my experience. I don't know that 5-10 minutes running cool between harder use be a concern. Until the unit is up to temperature I will run it. I shut off the unit when I have handwork on the forks or in the bucket--My ears and lungs can't take the fumes and banging working around the FEL (exhaust is right there).
   / Idle tractor or turn off? #13
I guess that I am in the 5 minute category give or take. I don't know how the different emissions engines will react to prolonged periods of idle. I would hope that 5 minutes here and there would not be a concern but we really don't know what the long term effects may be.
   / Idle tractor or turn off? #14
Tier4 and old school diesel operation has been a tough learning curve for me... old habits die hard.
I generally shut down the tractor if not being used for 5-10m. For brief idling I keep the engine at 1500rpm or so.
For my particular machine I set the throttle at 1500rpm, and let the auto throttle increase rpm's from there.
   / Idle tractor or turn off? #15
I've been letting mine idle if the out-of-cab work is 5 minutes or less. More than that, and it gets shut off. No point prematurely filling the DPF.
   / Idle tractor or turn off? #16
I'm in the 5 minute club. Longer than that wastes fuel and tractor hours. Starters and batteries are easy and fairly cheap to replace. Also, when I'm doing something like bucking wood, the idling engine would be somehow 'pressuring' me to hurry and get back on the tractor. I don't want to be hurried when cutting.
My dad shuts his tractor off almost any time he dismounts it. He has a 1982 Ford 1900 with around 2000 hours. No starter issues, doesn't eat up batteries any quicker than my tractors. No problems with his methods over the last 35 years. I think he leaves his big tractor running, however. Likes to keep the air con cooling...
   / Idle tractor or turn off? #18
Interesting question. From my 2005 JD 3520 Operators Manual:
Idling the Engine
NOTE: Allowing engine to idle for long periods of time will waste fuel and cause carbon build-up.
1. Adjust hand throttle lever to set engine speed at slow idle speed.
2. Lock the park brake.
Not sure what "long periods of time" means, but I'm in the 5-10 minutes club with many others. :) :turtle:
   / Idle tractor or turn off? #19
My tractor does not have any of that pollution crap on it. I don't worry about letting it idle for long periods at all. Mostly I shut it down if the noise is going to bother me, leave it running if it isn't.
Glad I have a simple NA diesel with out computers or pollution stuff. Glad I have a couple of manual transmission cars too. Hope my tractor lasts a long time because I would not buy a Tier 4 tractor.
   / Idle tractor or turn off? #20
As far as I know the dpf essentially only "works" when there is the soot trying to come out of the exhaust. And usually there is soot upon startup and under load where not all of the fuel gets burned in the combustion chamber.
Operating it at idle and at operating temps should result in no soot being created in the first place. Also if the tractor has a Regen cycle then the soot build up shouldn't be a concern as it essentially burns the soot up by injecting diesel into the exhaust and with increased exhaust temperatures created a high enough temp to combust the soot in the dpf.
Personally if I know I'll be off the tractor and not working on it for 20-30mins I turn it off.
If the tractor has a cabin which heats up or cools off, rather quickly. Frequent start ups also put a load on the heater or AC since you turn them up to heat or cool the cabin faster.
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
2009 IC School Bus (A55973)
2009 IC School Bus...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
