Ideas for pulling a stuck head?
/ Ideas for pulling a stuck head? #1
STx
Veteran Member
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
So this isn't exactly a tractor but, the International DT 360A was used in a lot of tractors and it's in my dump truck that I load with my tractor so, it's close...
I bought the dump truck in Dec and it ran great but, it appears that the previous owner didn't maintain the coolant system properly and we've got at least 1 perforated liner so I'm doing an in frame overhaul. I'm down to the head and have all the bolts out but, I can't get it to budge. I've always been able to break a head loose with a couple of sharp blows to the corners but, this is the first time I've worked on something this big or this old. It's a 1989 and there's no telling if it's ever been removed.
I know I can hammer a wedge or something in to start prying it apart but, I'd like to avoid that if I can do I don't risk doing damage to the head or, worse, the block. Does anybody have any suggestions?
/ Ideas for pulling a stuck head? #2
Try turning over the engine with the starter and see if the compression will pop it loose. You might want to put a few bolts back loosely just in case.
I managed to get it off this morning by getting a lever and fulcrum under a corner and putting some pressure on it. I guess it just needed to think about what was going to happen if it didn't comply to come to it's senses. Or my man muscles needed a night's rest to recharge. Or, I just got lucky. :)
/ Ideas for pulling a stuck head? #4
We never had to take heads off in the old days.
Bruce
/ Ideas for pulling a stuck head? #5
I hope it is a liner. Last time I had to replace a block because it had eroded between the sleeve and block.
Man, that sucks. If I find problems worth the block, I'll yank the whole thing and find a DT466 to put in it's place. The DT360A is a good motor but, the 466 is better and if it's all got to come out anyway, might as well go back with the more reliable of the two. It's a lot easier to find parts for the 466 as well.
/ Ideas for pulling a stuck head? #7
Just one night? You are lucky. :applause:
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
JOHN DEERE 606C - 6R30" CORN HEAD (A64277)
JOHN DEERE 606C -...
213135 (A64276)
213135 (A64276)
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
Mini Universal Root Rake (A65640)
Mini Universal...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
