Oil & Fuel Ideal Oil Pressure
/ Ideal Oil Pressure #1
F350
USA
Red
I have a Mahindra 485DI that has 30 pounds of oil pressure according to my gauge. Is this the correct pressure or is the oil pressure weak?
Thanks,
/ Ideal Oil Pressure #2
Thanks,
At what RPM?
Sorry....It has 30 pounds of oil pressure @ idle.
/ Ideal Oil Pressure #4
Engine hot? 30 psi is good.
The oil pressure is 30psi @ idle with a cold engine.
/ Ideal Oil Pressure #6
30 psi at idle with a hot engine and 10w40 oil would be excellent. I don't know, but would guess that the minimum spec is down around 10 psi hot idling. What oil are you using and what is the pressure when hot? What is the pressure when hot at PTO speed ?
jb
/ Ideal Oil Pressure #7
30 PSI at idle sounds good to me. Most low preasure warning systems are between 5-10 PSI and you are well above that.
Kubota L175 Tractor (A62613)
Kubota L175...
2016 Kubota RTV X1140 (A65563)
2016 Kubota RTV...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2014 GMC Savana Box Truck, VIN # 1GD072CA5E1907870 (A65563)
2014 GMC Savana...
100 gal L Portable Fuel Tank (A66408)
100 gal L Portable...
