Oil & Fuel Ideal Oil Pressure
/ Ideal Oil Pressure #1
F350
USA
Red
I have a Mahindra 485DI that has 30 pounds of oil pressure according to my gauge. Is this the correct pressure or is the oil pressure weak?
Thanks,
/ Ideal Oil Pressure #2
Thanks,
At what RPM?
Sorry....It has 30 pounds of oil pressure @ idle.
/ Ideal Oil Pressure #4
Engine hot? 30 psi is good.
The oil pressure is 30psi @ idle with a cold engine.
/ Ideal Oil Pressure #6
30 psi at idle with a hot engine and 10w40 oil would be excellent. I don't know, but would guess that the minimum spec is down around 10 psi hot idling. What oil are you using and what is the pressure when hot? What is the pressure when hot at PTO speed ?
jb
/ Ideal Oil Pressure #7
30 PSI at idle sounds good to me. Most low preasure warning systems are between 5-10 PSI and you are well above that.
2020 INTERNATIONAL LT625 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 INTERNATIONAL...
1990 Ford 3930 Tractor (A65579)
1990 Ford 3930...
Caterpillar 572E Tracked Pipe Layer (A64553)
Caterpillar 572E...
2024 ROADCLIPPER HDT207 T/A 22FT TILT TRAILER (A59914)
2024 ROADCLIPPER...
Case IH 5100 12ft. Soybean Special (A65640)
Case IH 5100 12ft...
King Kutter 5' 3Pt Tiller (A66285)
King Kutter 5' 3Pt...
