Oil & Fuel Ideal Oil Pressure
/ Ideal Oil Pressure #1
F350
USA
Red
I have a Mahindra 485DI that has 30 pounds of oil pressure according to my gauge. Is this the correct pressure or is the oil pressure weak?
Thanks,
/ Ideal Oil Pressure #2
Thanks,
At what RPM?
Sorry....It has 30 pounds of oil pressure @ idle.
/ Ideal Oil Pressure #4
Engine hot? 30 psi is good.
The oil pressure is 30psi @ idle with a cold engine.
/ Ideal Oil Pressure #6
30 psi at idle with a hot engine and 10w40 oil would be excellent. I don't know, but would guess that the minimum spec is down around 10 psi hot idling. What oil are you using and what is the pressure when hot? What is the pressure when hot at PTO speed ?
jb
/ Ideal Oil Pressure #7
30 PSI at idle sounds good to me. Most low preasure warning systems are between 5-10 PSI and you are well above that.
Crust Buster 15ft. Grain Drill (A65640)
Crust Buster 15ft...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2022 EZ-GO ELITE...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
F-250 Super Duty 4WD 6.2 (A63689)
F-250 Super Duty...
