Oil & Fuel Ideal Oil Pressure
   / Ideal Oil Pressure #1
F350
USA
Red
I have a Mahindra 485DI that has 30 pounds of oil pressure according to my gauge. Is this the correct pressure or is the oil pressure weak?
Thanks,
   / Ideal Oil Pressure #2
Thanks,
At what RPM?
Sorry....It has 30 pounds of oil pressure @ idle.
   / Ideal Oil Pressure #4
Engine hot? 30 psi is good.
The oil pressure is 30psi @ idle with a cold engine.
   / Ideal Oil Pressure #6
30 psi at idle with a hot engine and 10w40 oil would be excellent. I don't know, but would guess that the minimum spec is down around 10 psi hot idling. What oil are you using and what is the pressure when hot? What is the pressure when hot at PTO speed ?
jb
   / Ideal Oil Pressure #7
30 PSI at idle sounds good to me. Most low preasure warning systems are between 5-10 PSI and you are well above that.
2018 Nissan Titan Crew Cab Pickup Truck (A50323)
2018 Nissan Titan...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 Hitchai ZX470LC-5B Excavator (RIDE AND DRIVE) (A50774)
2014 Hitchai...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
