Buying Advice ID this Tractor
/ ID this Tractor #1
jjbenson
Zanesville, Ohio
Kubota L3400 and Massey 65 Mark II Dieselmatic, Bobcat 863H, Yanmar B50 Excavator, CAT E70B excavator, Massey 245
Hey Everyone-
I am hopefully picking up this MF tractor this weekend. I am getting it for a song, and I've been wanting a gasser to fix up. I don't even have data plate information on it right now. Can anyone tell me if its a 100 or 200 series? I'm guessing its a 35, or 40, but I can't tell. The large hydraulic cylinder on the left side makes me think 200 series. After buying and fixing up my MF 65 Diesel-matic last year, I kind of have a soft spot for Masseys, and as I said, the price was right. Engine is (or was) free. I know the starter is bad. She needs at least one rear tire. I'm sure there are plenty of other issues as well, but it has been sitting for 6 years. Other than the fact that the condition is poor, I'm looking for advice on what exactly it is, and if whatever it is happens to be, is a tractor I should stay away based on model. Any Help or insight would be appreciated!
/ ID this Tractor #2
Find the serial # and then check both series on tractor data. The serial #'s should be different for both series. Tractor data can help locate serial # if you have difficulty.
/ ID this Tractor #3
Maybe a 165 or 175
/ ID this Tractor #5
Based on the 235 that I had, i am guessing it is a 200 series:
/ ID this Tractor
/ ID this Tractor #8
Interesting you say that Steve, I tried to post on yesterdays tractors, but i can't even register. I keep getting a "forum use is disabled" message. I sent them an email, no word back yet.
Yikes. I've been a lurker there and haven't tried to register. Let us know what you find out.
Steve
/ ID this Tractor
Steve
Im currently in Germany. Not sure if that has anything to do with it, but I can't see that preventing me form even viewing posts. . I can access all other Forums I usually get on in the states no problem. Yesterdays tractors website brings up the most search hits on google for the Massey Im trying to ID, and I can't even view the threads .I can get on the website fine, The website isn't blocked, it just says Forum Use Disabled..Ill keep trying. Let me know if you can at least view threads. If you can, its probably my german internet blocking it. Lots of privacy stuff going on over here currently. Seems like every website i click on requires me to accept cookies and terms of use. Its getting kind of old...
/ ID this Tractor #10
Something from the 240 to 580 range. The distinct location of the air filter might be the giveaway for photo analysis. Scale of the pics suggests the lower end of the range.
Get the Seriel number and ring a local parts specialists for advise.
/ ID this Tractor #11
I can view threads at YT with no problems.:confused3:
Steve
/ ID this Tractor
So my father swears this is the only Data plate he can find. My older MF65 does not have TRACTOR written into the serial number, this is the first time I have experienced it- although my experience is limited. Anyway, I still can’t seem to get much info from just this serial number. It appears to match up with MF 165, 135, 250, and other I’m sure. Any ideas?IMG_4728.JPG
/ ID this Tractor #14
its gonna be a 1976 MF 245
9A242489 1976
9A257837 1977
/ ID this Tractor
9A2424891976
9A2578371977
Thanks M5, I should know more info tonight when the machine gets picked up. I’m curious where you got your information from? Just trying to learn as much as I can...
/ ID this Tractor #16
I just searched for the Prefix 9A that gave me the several models that had it then looked at each for the starting number after 9A , 1976 started 9A242489 yours is 9A249324 . 1977 started with 9A257837 so it was made in between the two starting numbers
TractorData.com Massey Ferguson 245 tractor information
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
V.E. ENTERPRISES 500 BBL FRAC TANK (A60736)
V.E. ENTERPRISES...
Used Landpride GR1525 Stump Grinder
Used Landpride...
2009 Ford F-150 Ext. Cab Pickup Truck (A60352)
2009 Ford F-150...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A61567)
2025 HT360W Mini...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
