Ice chains on a concrete floor.
   / Ice chains on a concrete floor. #11
I started the winter using plywood and scraps of carpet but now I just park the rear tires of my tractor on plywood but drive across the cement. I just make sure to not spin. My tires aren't filling but I have a 1000lb 55 gallon drum (cement filled) on the 3pt hitch. My cement was just poured last summer, it's 4000 psi. So far no marks at all.
   / Ice chains on a concrete floor. #12
in any case, I'd lay down a sheet of osb for thee winter. its 7 bucks a sheet and cheap insurance for the winter.
   / Ice chains on a concrete floor. #13
I have an asphalt driveway so I would have to lay down many sheets of OSB to prevent the chains from damaging everything. :p
~Kevin
   / Ice chains on a concrete floor. #14
Nah, you don't need many sheets...just two sheets and a willing assistant to continuously recycle the free one to the front of the tractor as you slowly make your way down the driveway...Ha!
   / Ice chains on a concrete floor. #15
I have a B7610 with V-bar chains on the rears and yes, they definitely chew up the concrete garage floor a bit.
I just studded the front tires last night. I'm curious if they will add to the problem, I suspect that they will. I've been thinking about throwing down some plywood but there's always a big puddle under the machine when all the snow melts off the blower.
   / Ice chains on a concrete floor. #16
Just wondering if anybody that uses ice chains keeps their tractor in a garage with a finished concrete floor.I have a chance to buy a set of ice chains for a good price but I am thinking they might damage my garage floor.I am talking about the chains that have studs welded to them to give traction on ice.My tractor is an L 3240 with FEL,backhoe and loaded tires that weighs about 7500 pounds.
My V-bars leave little marks everywhere they hit. I put down some scrap OSB to run on in my garage. Regular ladder chains probably won't mark up concrete too bad. I have 2-link ladders on my lawn tractor and that leaves no marks on concrete or asphalt (although it's about an order of magnitude lighter).
JayC
   / Ice chains on a concrete floor. #17
Ditto ... have started using heavy duty rubber backed throw rugs to protect the concrete floor.
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
Garbage Truck (A59230)
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
16ft Driveway Entrance Gate with Deer Design (A57454)
16ft Driveway...
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
