IBC 3 Point Watering Setup
/ IBC 3 Point Watering Setup #1
JOATMON3
Sophia, NC
John Deere 870
Here are some pictures from a watering setup I made last year. This pictures show some of the materials needed.
I believe the wire was 4 gauge stranded.
This 3-point pallet fork came from AgriSupply and was just over 200 with a 2000 pound capacity. My tractor has nearly a 2000 pound lift capacity so this is a good pair for me. Keep in mind water weighs about 8 pounds per gallon so this leaves me with a 200-250 gallon limit in the IBC which holds over 300 gallons full.
I attached a pump from Northern Tool that does 7gpm electric powered. It builds up to 60psi and turns off. It came with quick disconnect fittings so I pop those loose to let the pump drain for winter storage.
You can buy the fitting to go from IBC to garden hose from Amazon and then I got a female hose thread by slip connector from the irrigation section in a home improvement store.
The finished project with the tractor holding up about 200 gallons in the IBC tote. I found that putting a ratchet strap around the tank helps keep it from moving and/or sliding off. Attach a watering wand and off you go. I use this to do watering for trees. It make pretty quick work as it only takes about 8 seconds to deliver a gallon of water.
/ IBC 3 Point Watering Setup #2
Excellent job. These IBC totes are really handy for fuel, water, waste oil....
/ IBC 3 Point Watering Setup #3
Very very nice
/ IBC 3 Point Watering Setup #4
I like it :D.... did you wire it into the tractor or are you using another power source for the pump?
This gives me a cheaper initial method to move water - was/am thinking of doing something similar (in the longer term) with 2 IBC totes mounted on a EZ Trail compact running gear (where I figure I could load 400-500 gallons) and leverage a PTO/mounted pump with a home-built pressure-relief/distribution system for multiple hose/nozzle sizes. (yeah, I tend to overdo things)
/ IBC 3 Point Watering Setup #5
Here's my solution with an IBC tote.
HF 40"x48" trailer ($25 used). 12v boating sump pump down in the tank. A vacuum breaker (lawn sprinkler plumbing) at the highest point so the wand won't siphon when I turn the pump off, also that lets the wand drain so it is lighter, easier to lift after each tree, less tiring. (I built this rig the year that I had 125 new apple orchard trees to water).
The weight is way above the trailer's rated capacity but I don't need highway-grade safety margin. Nothing has broken in near 10 years using this.
267962d1338652506-harbor-freight-tools-dont-suck-p1670184ribcwateringtrailer-jpg
/ IBC 3 Point Watering Setup #6
I need to make one like this.. perhaps one of my retirement projects..
/ IBC 3 Point Watering Setup #7
Yeah, they are, but there's no way I could get up my back hill with either one of these. I set one down in the back bottom field on some RR ties to raise it above ground so a gravity watering system would work for the 20 trees I have down there. Old 35 gallon plastic garbage can lid serves as a catch bowl and funnel for rain to help keep the level up.
/ IBC 3 Point Watering Setup #8
I have a Sotera Systems pump to move both hay preservatives and water from IBC totes and 55 gallon drums. It has a telescoping pick up for various depth of containers. On/off switch and long alligator clip leads to connect to tractor or truck battery.
/ IBC 3 Point Watering Setup #9
Does that little pump put out a similar gpm to a regular garden hose?
2010 Ford Crown Vic (A62679)
2010 Ford Crown...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
90in. Work Bench (A65640)
90in. Work Bench...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
Kinze KM3000 Monitor (A65640)
Kinze KM3000...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
