I would like to add a backhoe attachment. What are my options?
   / I would like to add a backhoe attachment. What are my options? #1
asgreig
John deere 2210
I have a jd 2017 2038r with no hydraulics to the rear and I would like to add a backhoe attachment. What are my options?
Add rear hydraulics or find a stand alone that runs off rear pto ? any other options?
   / I would like to add a backhoe attachment. What are my options? #2
Mine has a PTO pump, I'm not big on tapping into my tractor system.. Make sure that you get one with a subframe.
   / I would like to add a backhoe attachment. What are my options? #3
For the 8-9K you are going to invest in a BH its better to get a mini excavator - you can get the 1 Ton units for $5-6K but the better machine is the 2 ton with diesel for $11-12K.
   / I would like to add a backhoe attachment. What are my options? #4
JD makes a system for your machine. Like already pointed out it’s expensive. Less if you can install it yourself. It will tap into your tractors existing hydraulic system, how exactly I don’t know.
   / I would like to add a backhoe attachment. What are my options? #5
I agree. For the price you guys can get those mini ex in the US, it's a no brainer.
You get a dedicated machine built to handle that type a work, that you can swing 360 degrees and you're not putting all those stresses on a tractor that wasn't built to have a backhoe in the first place.
   / I would like to add a backhoe attachment. What are my options? #6
Depending on your uses, renting a mini-ex may also work.
   / I would like to add a backhoe attachment. What are my options? #7
When I decided I wanted a backhoe I called the dealer who sold my tractor. They happened to have a used backhoe for my model that they'd just gotten in. It cost a bit more than half what a new one cost.
There was a factory kit to add the hydraulic ports for the backhoe that worked with or without factory remotes. It was easy to install. It'll be different for your tractor but it's probably not too hard to install.
I bet you could find it in the parts lookup on deere's web site.
   / I would like to add a backhoe attachment. What are my options? #8
PTO & Subframe are probably the best way. Certainly a subframe makes any BH work way better and is safer.
The old 3pt mount backhoe attachments were so dangerous that for years you saw posters warning about them in tractor dealerships. Mine damn nearly got me - but I still used it for years. Having a subframe prevents problems.
As for hydraulics you've covered the two main options: PTO or rear remotes. Rear remotes are simple enough to do yourself if you already have a loader, and not too bad if you don't.
If you have a FEL with a power beyond port, plumbing a set of rear remotes by buying the parts & doing it yourself is an under $500 job - but youdo have to study up on things like the world of hydraulic fittings and disconnets....not simple stuff & took me many evenings.
If using a manufacturer's kit to do the same thing probably twice that. Having the dealer install the kit doubles it again.
I think having a hoe with a thumb is a wonderful thing. Particularly for us older guys.
rScotty
Reality just knocked. :cry: Another dream gone lol
1992 Ford L9000 Cab Chassis with Low Mileage Cummins (A56436)
1992 Ford L9000...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
20ft Driveway Entrance Gate w/ Deer Design (A57454)
20ft Driveway...
Kubota L4701 (A53317)
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2018 Kaufman 20-Ton Equipment Trailer, VIN # 5VGAP2528JL004708 (A57453)
2018 Kaufman...
