I want a Clean Mower Deck!
   / I want a Clean Mower Deck! #11
Mornin John,
Nice job ! I bought a small Toro Zero turn this year, 42" and they have basically the same thing on their deck but its plastic ! I like yours better !
   / I want a Clean Mower Deck! #12
My Cub Cadet Z-Force 50 has the deck wash system. The hose end is the same plastic quick connects sold for garden hoses at Wal Mart or Home Depot. Works pretty well when I remember to do it.
MarkV
   / I want a Clean Mower Deck! #13
other ideas for nosels.....
a series of small holes drilled in the cap
cut with a hacksaw for a ultra thin slot
   / I want a Clean Mower Deck! #14
I like your idea! I saw something similar on riders at Home Depot.
Also, somebody else on TBN appended an idea for a pipe assembly he had made, that layed out on the ground, with holes facing upward. I think he said he'd drive overtop of this assembly then turn on the water and run the mower. A couple or a few jets streaming up into the running deck cleaned it out.
Do these ideas really work to clean the deck (assuming you do it when you finish mowing, not a week later or something) ?
If so, I am going to give one or the other a try.
   / I want a Clean Mower Deck! #15
Very good idea.
To add to the ideas foir keeping a mowing deck clean, my dad's friend has a good system.
He uses something he called "Slip plate" underneath his mowing deck. It is like a paint, made for metal grain chutes, or anywhere dry materials are being conveyed.
It's like teflon paint, makes a no stick surface.
My dad painted the bottom of his 48" mowing deck with it, years ago, and it still cleans out real easy with just standard garden hose pressure.
   / I want a Clean Mower Deck! #16
Here you go. Works great!
   / I want a Clean Mower Deck! #17
bigdad, What kind of coating is that? Where did it come from? More details, please!
   / I want a Clean Mower Deck! #18
bucmeister
That coating is called Slip Plate. I get it (where I work) in a gallon can, but you can buy it at most farm stores. I slop it on with a brush to a clean surface. Covers and sticks real well, but nothing will stick to it. I paint the blades and all. I plan to do the mold board on my back blade too. It eventually wears off, so I just throw on some more.
Good luck. B.D.
   / I want a Clean Mower Deck! #19
I've been using my loader and a chain to lift the front of my Craftsman tractor for years. I pressure wash it and it really cleans the deck. Just got a Cub GT 1554 with the deck wash system. I guess I'm just use to really getting it really clean. The deck wash system gets the big chunks off but still leaves quite a bit of residue. Back to using the loader. I'm going to try the coating mentioned earlier and see if the deck wash system works well enough.
   / I want a Clean Mower Deck! #20
Bucmeister,
I just finished sandblasting and applying slip plate onto my Kubota 72" mower deck. It looks great and hope that it keeps the grass from sticking to the deck. I had not been as diligent on cleaning the deck off in the last year and I had quite abit of rust on the deck which I had to remove with the sandblaster. I will be mowing tonight for the first time since the Slip Plate has been applied and will have to report back later.
Lively1
bigdad said:
bucmeister
Good luck. B.D.
2017 Ford F-350 Flatbed Truck (A56858)
2017 Ford F-350...
HAMM HD120HV DOUBLE DRUM ROLLER (A52707)
HAMM HD120HV...
19015 (A53422)
19015 (A53422)
2006 Acura RL Sedan (A55853)
2006 Acura RL...
2018 Ford F-250 4x4 Crew Cab Pickup Truck (A55852)
2018 Ford F-250...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
