I want a Clean Mower Deck!
   / I want a Clean Mower Deck! #11
Mornin John,
Nice job ! I bought a small Toro Zero turn this year, 42" and they have basically the same thing on their deck but its plastic ! I like yours better !
   / I want a Clean Mower Deck! #12
My Cub Cadet Z-Force 50 has the deck wash system. The hose end is the same plastic quick connects sold for garden hoses at Wal Mart or Home Depot. Works pretty well when I remember to do it.
MarkV
   / I want a Clean Mower Deck! #13
other ideas for nosels.....
a series of small holes drilled in the cap
cut with a hacksaw for a ultra thin slot
   / I want a Clean Mower Deck! #14
I like your idea! I saw something similar on riders at Home Depot.
Also, somebody else on TBN appended an idea for a pipe assembly he had made, that layed out on the ground, with holes facing upward. I think he said he'd drive overtop of this assembly then turn on the water and run the mower. A couple or a few jets streaming up into the running deck cleaned it out.
Do these ideas really work to clean the deck (assuming you do it when you finish mowing, not a week later or something) ?
If so, I am going to give one or the other a try.
   / I want a Clean Mower Deck! #15
Very good idea.
To add to the ideas foir keeping a mowing deck clean, my dad's friend has a good system.
He uses something he called "Slip plate" underneath his mowing deck. It is like a paint, made for metal grain chutes, or anywhere dry materials are being conveyed.
It's like teflon paint, makes a no stick surface.
My dad painted the bottom of his 48" mowing deck with it, years ago, and it still cleans out real easy with just standard garden hose pressure.
   / I want a Clean Mower Deck! #16
Here you go. Works great!
   / I want a Clean Mower Deck! #17
bigdad, What kind of coating is that? Where did it come from? More details, please!
   / I want a Clean Mower Deck! #18
bucmeister
That coating is called Slip Plate. I get it (where I work) in a gallon can, but you can buy it at most farm stores. I slop it on with a brush to a clean surface. Covers and sticks real well, but nothing will stick to it. I paint the blades and all. I plan to do the mold board on my back blade too. It eventually wears off, so I just throw on some more.
Good luck. B.D.
   / I want a Clean Mower Deck! #19
I've been using my loader and a chain to lift the front of my Craftsman tractor for years. I pressure wash it and it really cleans the deck. Just got a Cub GT 1554 with the deck wash system. I guess I'm just use to really getting it really clean. The deck wash system gets the big chunks off but still leaves quite a bit of residue. Back to using the loader. I'm going to try the coating mentioned earlier and see if the deck wash system works well enough.
   / I want a Clean Mower Deck! #20
Bucmeister,
I just finished sandblasting and applying slip plate onto my Kubota 72" mower deck. It looks great and hope that it keeps the grass from sticking to the deck. I had not been as diligent on cleaning the deck off in the last year and I had quite abit of rust on the deck which I had to remove with the sandblaster. I will be mowing tonight for the first time since the Slip Plate has been applied and will have to report back later.
Lively1
bigdad said:
bucmeister
Good luck. B.D.
UNUSED FUTURE FT-LJB12 POLYTHYLENE BOARD (A57193)
UNUSED FUTURE...
2009 GMC C8500 Altec DM47 47ft Insulated Digger Derrick Truck (A55852)
2009 GMC C8500...
John Deere 1025R (A53317)
John Deere 1025R...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
UNUSED 1RANCH 1RETC HYD THUMB CLAMP (A57193)
UNUSED 1RANCH...
Toro Mower (A50324)
Toro Mower (A50324)
