I think my tail wheel is too big
   / I think my tail wheel is too big #61
It appears that the yoke stem is bent at the blue arrows. The orange arrow points to what also might be bent. If it was meant to be that way, wouldn't it be easier and less expensive to just grind an angle on the stem where it welds to the yoke plate?
The second photo is my Bush Hog Squealer 480. Slightly different design but note that the stem and yoke plate are built at 90 degrees to each other.
Your mower's tail wheel was in a collision.
   / I think my tail wheel is too big #63
I have enjoyed following this thread.
As usual, A LOT of good advice has been given to the OP's initial question.
What I find interesting is this. Here you have a simple question asked. This similar type question is asked by the hundreds over the course of a week on this board. However, most are lucky to get anywhere from 5-10 responses from all of the 1,000's of members on this board.
So, what is different about this post?
Why has this particular question gotten 60+ responses and climbing. It doesn't seem like the posts have slowed hardly at all.
Now, has the original poster yet said what course of action he is taking?
Great place for knowledge and entertainment.
Keep it up. :thumbsup:
   / I think my tail wheel is too big #64
IMO, pictures and prompt responses from the OP.
Aaron Z
   / I think my tail wheel is too big #65
IMO, pictures and prompt responses from the OP.Aaron Z
Very true.
Those 2 things always help when trying to offer advice or some course of action on this forum.
   / I think my tail wheel is too big #66
I could care less about the tail wheel assembly. Its hella expensive to replace.
There is a second set of bolt holes farther back on the mower deck that he could move the tail wheel arms to.
He would have to relocate the up/down adjustment for the tail wheel, but given the nature of most hobby farm people, that may be a much simpler and way cheeper fix than buying a new $100+ tail wheel assembly.
   / I think my tail wheel is too big #67
Certainly bent and, I would want a washer at the top for the pin to bear on...the variety of other pics posted of other designs illustrate the difference between "caster" and "kingpin alignment" IMHO.
The weld of the fork onto the (should-be-) vertical shaft seems like a refit and if there is some slop between that shaft and its tube, I'd suspect someone welded on an undersized shaft ...which has allowed it to be bent ...it should not be a sloppy fit but snug w. just some space for grease. This retrofit of the shaft would account for it extraordinary length (w. no other through holes for fastener)
   / I think my tail wheel is too big #68
The only problem with this tailwheel is a bad previous repair job. Someone has lengthened and stepped down the diameter of the shaft before the weld to the yoke. This is weak and has bent, resulting in the excessive caster and interference with the deck. Just get a new shaft/yoke unit with the same diam. shaft--should be less than $50. A Land Pride or Bush Hog one would probably work. It looks like the tube at the end of the arms is worn at the rear also. Fabricate a new one to the length required by the shaft/yoke unit you buy. Drill and tap a grease fitting and keep it lubricated. Don't try to salvage the messed up shaft/yoke by heating and straightening. It will be even weaker than before and will quickly bend, leaving you right back where you were.
   / I think my tail wheel is too big #69
Maybe its bent?:D
   / I think my tail wheel is too big #70
Does this bush hog make my tail wheel look big?
Sorry, couldn't resist... :D
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
CAT Skid Steer (A50322)
CAT Skid Steer...
2008 Toyota RAV4 AWD SUV (A50324)
2008 Toyota RAV4...
1996 Lincoln Town Car Signature Sedan (A50324)
1996 Lincoln Town...
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
