I suck at using rachet chain binders...help
   / I suck at using rachet chain binders...help #21
One way you can save a lot of trouble and effort is to chain up the front end as snug as you can without binders and then back up 'till nice and tight and apply the parking brakes.(like squish the front tires)
You then only need to manually tighten the rear end.
That way you have only one binder to bother with.
   / I suck at using rachet chain binders...help #22
Make sure the binder is extended as far as it can go and then you pull the chain as tight as you can by hand taking out any slack and then hook the binder to the tightest link you can reach. I use ratchet binders all the time and never have problems. Are you wrapping the the chains around things? Chain doesn't like to slide too well when wrapped around things. Hook it to an anchor point on each end and then tighten.
   / I suck at using rachet chain binders...help #23
I will take a ratchet (screw type) binder over lever type any time. The trick is, as stated already, getting as much slack out as possible first, and having the binder as open as possible and still have 2 or 3 threads catching.
If you use lever binders, intentionally twisting the chain can shorten it just enough when you find one link you hook to, too tight, and the next too loose. Again, only after getting all the slack out.
   / I suck at using rachet chain binders...help #24
I hate lever binders. To get them tight enough you need a cheater which makes one more thing you have to carry around. My grandfather had his ankle shattered with one when it came loose years ago. They are dangerous. I know they are outlawed by several organizations. We were doing some work where we had a Canadian consultant there that worked primarily in the mining industry. We had a couple lever binders at the time. He could not believe it said they were forbidden up there in his industry due to numerous accidents.
   / I suck at using rachet chain binders...help #25
DRancher has the right idea IMHO. Some of these photos are looking like binder mainia. BIG and heavy stuff we use multiple binders and chains on. Something like a L4400 with bucket and 3pt attachment I use a chain in front and a chain in back with one binder on each one. I don't go running around trying to shake the thing off the trailer, gents. When you get into four tons to sixty tons, well by golly throw every chain and binder in town on em. Give me a good old USA knucklebuster and cheater bar any day.
   / I suck at using rachet chain binders...help #26
I prefer the widow makers and a 3' snipe pipe, but then again I have never used the ratchet type binders. Whatever binder you use, you must get as much slack out of the chain as you can.
   / I suck at using rachet chain binders...help #27
Looking at the OP's pics, it looks like he's not hooking the chain at both ends, then using the binders to tighten the chain up. This is the way I use my ratchet binders and I've never had any problems.
I have both lever and ratchet and prefer ratchet, far more control IMO. But I can see if you used them daily it would get old fast.
   / I suck at using rachet chain binders...help #28
10 or so years ago an employee here was using a lever binder and pipe,
and either he let go while cinching down, or opening the lever and the pipe
caught him square in the face/nose. quite a mess, blood everywhere, he
ended up ok after all the cuts and bruises healed, but it was an ugly accident.
there is something to be said about the ratchets in that regard. (although we
mostly use lever type here still)
   / I suck at using rachet chain binders...help #29
I have 4 new ratchet binders. I can't stand them. I bought new lever type. I can have the tractor changed down faster with the lever type than the ratchet type.
   / I suck at using rachet chain binders...help #30
No problem with ratchets here, other than sometimes you need to plan things in tight spaces to make sure there is room to swing the handle around. I always use them in the middle of the chain, far from the ends/anchors. I basically gather up (pinch) the slack and use the binder to bridge across it.
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A51222)
2020 INTERNATIONAL...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
2006 GMC C7500...
