I suck at using rachet chain binders...help
/ I suck at using rachet chain binders...help #41
Serious question though...why not ratchet straps? I know the 3" ones are rated for the load, but I know very little about securing loads so please fill me in.
I'm not saying I don't like the idea of chains and binders, but really, why not ratchet straps?
Un Oh, the worm can just got opened.
/ I suck at using rachet chain binders...help #42
yep, might as well start them crawling across the floor, so here goes..
Three reasons.. straps are subject to getting cut on sharp metal. they are subject to stretch, and you just cant put the tightening pressure on them like you can binders/chain.
Opinions only on my part.. let the flames begin...:)
/ I suck at using rachet chain binders...help #43
Good chain used with a ratchet binder can tear up SCUTs and CUTs if you over do it.
/ I suck at using rachet chain binders...help #44
I was actually serious with my earlier post about straps. I use big 3" straps. I find the little bit of stretch in them somewhat useful and they get plenty tight for me. They are lighter and easier to store and have never had one break. The downside, as mentioned, is their ability to be cut. I usually only only use the hooks with nothing else touching, but if I need to go over something with the strap itself, I have little pieces of rubber mat to protect the strap.
If I was tying down a 30 ton excavator, it would be different because a little stretch-ability with that much weight could equate to movement. It is a non-issue with a 4k tractor or a car. Thats just me though.
I do use a chain on the front of my tractor, then back up to tension the chain and set parking brake. Tension with 2 straps on the rear, then release parking brake.
/ I suck at using rachet chain binders...help #45
I am with you. Cars and small tractors I use 2" straps and axle straps. If the load is over 6000# then I use my chains and binders.
The law states straps are ok for rolling loads under 10,000#. I take care and in 20 years never had a strap cut or damaged.
Chris
/ I suck at using rachet chain binders...help #46
Good question about straps. If they are acceptable on tractor trailer loads, why not smaller loads?
/ I suck at using rachet chain binders...help #47
Can you point me to where straps are prohibited for loads over 10k#?
Looking on the FMCSA site, the only restriction I see is for hauling crushed cars:
http://www.fmcsa.dot.gov/rules-regulations/truck/vehicle/cs-policy.htm said:
& sect;393.128 What are the rules for securing automobiles, light trucks and vans?
Applicability. The rules in this section apply to the transportation of automobiles, light trucks, and vans which individually weigh 4,536 kg. (10,000 lbs) or less. Vehicles which individually are heavier than 4,536 kg (10,000 lbs) must be secured in accordance with the provisions of & sect;393.130 of this part.
Securement of automobiles, light trucks, and vans.
Automobiles, light trucks, and vans must be restrained at both the front and rear to prevent lateral, forward, rearward, and vertical movement using a minimum of two tiedowns.
Tiedowns that are designed to be affixed to the structure of the automobile, light truck, or van must use the mounting points on those vehicles that have been specifically designed for that purpose.
Tiedowns that are designed to fit over or around the wheels of an automobile, light truck, or van must provide restraint in the lateral, longitudinal and vertical directions.
Edge protectors are not required for synthetic webbing at points where the webbing comes in contact with the tires.
& sect;393.130 What are the rules for securing heavy vehicles, equipment and machinery?
Applicability. The rules in this section apply to the transportation of heavy vehicles, equipment and machinery which operate on wheels or tracks, such as front end loaders, bulldozers, tractors, and power shovels and which individually weigh 4,536 kg (10,000 lbs) or more. Vehicles, equipment and machinery which is lighter than 4,536 kg (10,000 lbs) may also be secured in accordance with the provisions of this section, with & sect;393.128, or in accordance with the provisions of & sect; & sect;393.100 through 393.114.
Preparation of equipment being transported.
Accessory equipment, such as hydraulic shovels, must be completely lowered and secured to the vehicle.
Articulated vehicles shall be restrained in a manner that prevents articulation while in transit.
Securement of heavy vehicles, equipment ormachinery with crawler tracks or wheels.
In addition to the requirements of paragraph (b) of this section, heavy equipment or machinery with crawler tracks or wheels must be restrained against movement in the lateral, forward, rearward, and vertical direction using a minimum of four tiedowns.
Each of the tiedowns must be affixed as close as practicable to the front and rear of the vehicle, or mounting points on the vehicle that have been specifically designed for that purpose.
& sect;393.132 What are the rules for securing flattened or crushed vehicles?
Applicability. The rules in this section apply to the transportation of vehicles such as automobiles, light trucks, and vans that have been flattened or crushed.
Prohibition on the use of synthetic webbing. The use of synthetic webbing to secure flattened or crushed vehicles is prohibited.
Securement of flattened or crushed vehicles. Flattened or crushed vehicles must be transported on vehicles which have:
Containment walls or comparable means on four sides which extend to the full height of the load and which block against movement of the cargo in the forward, rearward and lateral directions; or
Containment walls or comparable means on three sides which extend to the full height of the load and which block against movement of the cargo in the forward, rearward and the lateral direction for which there is no containment wall or comparable means, and
A minimum of two tiedowns are required per vehicle stack; or
Containment walls on two sides which extend to the full height of the load and which block against movement of the cargo in the forward and rearward directions, and
A minimum of three tiedowns are required per vehicle stack; or
A minimum of four tiedowns per vehicle stack.
In addition to the requirements of paragraphs (c)(2), (3), and (4), the following rules must be satisfied:
Vehicles used to transport flattened or crushed vehicles must be equipped with a means to prevent loose parts from falling from all four sides of the vehicle which extends to the full height of the cargo.
The means used to contain loose parts may consist of structural walls, sides or sideboards, or suitable covering material, alone or in combinations.
The use of synthetic material for containment of loose parts is permitted.
Aaron Z
/ I suck at using rachet chain binders...help #48
Aaron Z
"Rolling loads" I was told by a LEO were limited to straps for loads under 10K. I agree, by the law you posted it's not.
Guess this all comes back to the local smokey.
Chris
/ I suck at using rachet chain binders...help #49
That's why I use straps threaded around both the front and back axles on my B2620. Yet tears are still possible, so I may use towel if indicated. One thing that I wonder about is the heat in the rear axle after mowing for a couple hours. So I sit for awhile and have a cold drink myself. Thus the strap may not be compromised by the heat.
/ I suck at using rachet chain binders...help #50
Chris
I agree. I don't have problems with appropriate straps either. I had a set of four short 3" straps to tie down my rockrawler. I used those same straps for my tractor for a couple of years.
/ I suck at using rachet chain binders...help #52
are you required to use a binder on a chain?
pass chain through bumper of tractor, back tractor up tension chain (no binder), put chain on rear of tractor, tension with binder (of your choice)
/ I suck at using rachet chain binders...help #53
Great thread.
Having grown up helping out in my Dad's heavy construction business, I am comfortable with the chain binders but, to be fair, I never saw a ratchet binder during those years. I did see plenty of heavy, nylon slings, for lifting large objects (his business evolved into strictly hydraulic cranes, from 6 to 55 ton), and some slings were probably 4"-6" wide.
It's been a lot of years since I've used a chain binder, and the fact that their "stroke" is shorter than the ratchet type is a good point, in favor of the ratchet binders. Thanks to whoever pointed that out--I did not know that.
As I have OCD, I think I'd like the ability to "tweak it a little," at a rest stop, with the ratchet binders--that is their biggest appeal to me (theoretically, as I haven't tried them yet). Because, when I use a 3" ratchet strap on my boat, I do like the ability to "tweak it," a bit, underway, if she "walks on the bunks," a little, as does happen, rarely.
However, I do like the speed of the chain binders. Yet, as has been mentioned, I'd be concerned about possibly bending something on these SCUTS and CUTS, as opposed to on a Cat 977 (tracked loader--which IIRC, weighed 17 tons). He used to do "dirtwork," as well as cranes, but then specialized in strictly hydraulic cranes. Very cool machines, if you ever get a chance to play with one. (Put your outriggers out first, however! LOL).
Side note: I found that the synthetic ratchet tie on the boat (across amidships, about 6' from the transom) is tight enough if it matches the first note in The Who's "Behind Blue Eyes." Because it's a 22.5' aluminum boat (Mercruiser, I/O), I don't want to "crush" it, which I wouldn't worry about if it were a fiberglas boat. So the "tight enough but not too tight" dilemma obtains. (My guitar playing--chords only--is so bad, that I can't say for sure, but it sounds like a "G" note--perhaps a TBN musician can confirm or school me?) I just start singing the song, "thrum" the strap, hear that it matches the note, and I'm good.
But then again, I'm "not right." :laughing:
Excellent thread, though. Takes me back. Keep it comin'--pics help, too!
My Hoe
/ I suck at using rachet chain binders...help #54
As an insurance guy, I can tell you we've seen a lot of back claims over the years on truckers from lurching on binders, or the strap ratchets that you see on the side of semi trailers. We've also had some claims where they cut the binder loose and the load goes tumbling. This can tend to happen on things that are stacked like poles, posts, railroad ties, cattle panels, etc.
I would think that undoing a ratchet binder, you could kind of control the release that way as opposed to a lever where it pretty much lets go all at once.
/ I suck at using rachet chain binders...help #55
Last sentence is another good case for ratchets. And as others have said- I back off ratchet until just a couple of threads are holding before ratcheting down. A little bit of care up front and they are a non issue. Also whenever possible, get one ratchet hook on nstake picket or rail-with the stake pocket serving as a stop to keep from sliding. In any case good thread.
/ I suck at using rachet chain binders...help #56
[/B]
PS-forgot to mention-nothing like ratchets with "USA" cast into the handles. I may be old but I just don't trust a casting made in China. You get what you pay for.
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
New/Unused Wolverine 3 Point Hitch Coupler (A65583)
New/Unused...
2021 UTILITY VS2DX 53x102 T/A DRY VAN TRAILER (A59914)
2021 UTILITY VS2DX...
2014 Chevrolet Equinox SUV (A64557)
2014 Chevrolet...
2022 EZ-GO ELITE...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
