I suck at using rachet chain binders...help
   / I suck at using rachet chain binders...help #1
v8only
Mb
1988 John Deere 755
So as title says I suck at securing my trailer load. I have 5/16" transport chain and ratcheting binders, i pull the chain as tight as i can and start to ratchet it but it can never get the chain tight it seems to always find a way to pull up more slack and then i run out of thread and have to restart. I need some pointers.
   / I suck at using rachet chain binders...help #2
Do you start by running the binder threads out as far as is safe before hooking the chain on?
yes i do, i should have mentioned that.
   / I suck at using rachet chain binders...help #6
It sounds like your chain is running a long ways. Where are you specifically attaching your chains at?
   / I suck at using rachet chain binders...help #7
Ya know, i use to have the same problem with the screw type, i got to the point I threw them under the bench and bought the Non-Ratcheting Load Binder. No problem since then just a little poorer in the wallet! Just remember to wire the handle of the binder to the chain. :laughing: . . .John
   / I suck at using rachet chain binders...help #8
Ratchet binders don't work well if you try to use them like a knuckle buster binder. Always attach a ratchet binder with one end hooked to a stationary point of the trailer and the other to the chain. If you loop the chain through a d-ring (and the other end is also attached through a d-ring) you'll drive yourself crazy trying to get enough slack out. That's why I prefer pocket attachment points to d-rings.
Another thing to watch is to make sure the chain isn't twisted, which makes the chain shorter in length. The ratchet binder will straighten out the links and the chain gets longer while you're tightening.
good to know.What i do is i wrap my chain around a D ring to a clevis at the tractor then into another D ring and then try to remove the slack. I will try to use a stationary point of the trailer and see how i make out.
Thanks.
   / I suck at using rachet chain binders...help #10
Thanks.[/QUOTE
I have the same problem, bought 'em and threw in the box on the truck. Back up only. Use the ole' handy boomers. Works for me and a lot quicker.
2015 FREIGHTLINER CASCADIA DAY CAB (A51219)
2015 FREIGHTLINER...
2011 Liebherr L586 (A52128)
2011 Liebherr L586...
CATERPILLAR 279D3 SKID STEER (A51242)
CATERPILLAR 279D3...
7046 (A50322)
7046 (A50322)
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
