I Still Hate My Tractor II
   / I Still Hate My Tractor II #382
I'm curious what the stock ring land width is and what they measure now. Is there any chance they are setup with this much clearance from the factory?
Also curious if they run a bit more ring end gap on turbo motors.
Added in edit on 10/28/19
I couldn't find any difference in the specs for turbo and non-turbo with respect to ring gap or clearance.
Did find it interesting the top ring clearance was omitted from the specifications in two different places within the WSM.
Here's what I need, steel ring land for top ring.
V23t Piston 1g7-2111 1g77-21112 V23t Liner V23t Engine Parts - Buy V23t Piston 1g7-2111 1g77-21112 V23t Liner V23t Engine Parts,V23t Full Gasket Set V23t Head Gasket,V23 Exhaust Valve V23 Inlet Valve V23 Valve Guide Product on Alibaba.com
   / I Still Hate My Tractor II #384
This is what happens when you over fuel and boost an engine not designed for it. The wastegate is set at 6.5 pounds (factory).
Looks like I'll replace 4 pistons, rings and remove the turbo then sell it in the Spring because the power will be so bad.
View attachment 626339View attachment 626340View attachment 626341View attachment 626342
This is why they say buyer beware folks....
No offense Fred, but I sure hope I'm the not the guy that buys your used tractor that you seriously abused. In fact, this is the reason I will mostly only buy new items. You really should have just traded it right away when it didn't satisfy your needs. Now some poor young sap will probably buy a used tractor for his first ever huge purchase and be all excited until he realizes he got stuck with a mess.
Buyer beware for sure!
Other than beating it badly while blowing snow it really isn't too bad. There's not any dents, damage other than crap faded paint. The service was done at about 1/2 intervals.
The axle leak problem will be fixed with a new driveshaft and seals and the engine will be tip top shape with new pistons and everything checked properly including injectors.
Hey it'll be tested tough and road ready for the next guy!
Seriously, David. I have a friend who sells Kiotis for a living. He recently took in trade a decent L5740 cab with low hours. He rented it once for a job and it came back with the infamous split pin leak so he had his guys split it and replace all the seals including the one in the front diff.
He wasn't too happy and doesn't want to take these lemons in trade toward an outstanding quality new Kioti:licking: I can't say as I blame him.
   / I Still Hate My Tractor II #386
From what I have read about The Fred, and his posts, he sounds like he is fairly qualified on building these diesels. Much more than myself.
BUT, I would hope he informs any potential purchaser of this tractor what its life has consisted of!
   / I Still Hate My Tractor II #387
The Fred has always seemed to be a straight shooter.
   / I Still Hate My Tractor II #389
No clue about yer neck of the woods, but around here; crooked folk generally can't afford to do much shooting, so they mostly all shoot crooked. Generally when speaking of the crooked, folk swap 'shooter' out for other things like "he's a crooked S o B" or "he's a crooked S--t" and so on...
:D
   / I Still Hate My Tractor II #390
Maybe straight, should have meant accurate. Or that he isn't using a firearm with a bent barrel. That wouldn't make him very unique, though.
MAYBE, does a lot of shooting in outer space. That would make perfect sense.
2018 Ford F-550 Altec AT48S 47ft. Bucket Truck (A55973)
2018 Ford F-550...
2025 Wolverine SP-15-84W 84in Snow Pusher Skid Steer Attachment (A55973)
2025 Wolverine...
Eagle Weathervane (A55853)
Eagle Weathervane...
1991 International 4900 Box Truck (A55315)
1991 International...
2013 International Derrick Digger Truck (A55973)
2013 International...
2010 Chevrolet Silverado 1500 (A55973)
2010 Chevrolet...
