Buying Advice I need to replace my JD2240 tractor
   / I need to replace my JD2240 tractor #1
mark vetter
elma wa.
kubota L4350 jd2240 kubota 8540
Hi gang, my 1979 jd2240 tractor has combustion gas entering cooling system. I think i will get a newer 4wd tractor with a cab and fel to replace it. The tractor will be a general purpose farm tractor which does a bit of everything on a farm that makes little real money. I like the kubota M7040 with a shuttle but all require buying out of state and hiring a transporter. If you were me what tractors in the 70-80 engine hp range would you suggest. my budget is about $34000. Also. should I be afraid of doing business perhaps bringing a tractor 2000 miles away.
   / I need to replace my JD2240 tractor #3
Elma is thirty miles from Olympia and several other Puget Sound cities. There are likely John Deere dealers in at least four cities plus Kubota dealers.
Why do you feel pressure to buy out of Washington state, with the uncertainty that entails?
Aberdeen, WA
Shelton, WA
Hoquiam, WA
Tumwater, WA
Olympia, WA
Lacey, WA
Centralia, WA
University Place, WA
Lakewood, WA
Spanaway, WA
Parkland, WA
Tacoma, WA
Bremerton, WA
Kelso, WA
   / I need to replace my JD2240 tractor #4
Be a discerning patient shopper. Take your time looking.
Jeff, there are only 2 M7040 tractors available in my entire state and they are too pricy. Most available are out of state. My main query to the forum is, what are some suggestions as to what 4wd tractors in the 70-80 engine hp are well thought of.
   / I need to replace my JD2240 tractor #6
Why the 7040? Are you set on pre tier IV?
Pretty much anything from JD with an "R" or "M" should be fine. Avoid the "E" line.
thanks, the m7040 is right hp and old enough to fit my budget. I am hesitant to step up to tier 4. seems like more hassle for no gain.
   / I need to replace my JD2240 tractor #8
There are 5 M7040's showing up on Fastline.com within 200 miles of Olympia WA. Be patient and keep looking. Something you'll like will turn up. Also agree that the higher end Deere utilities could be a good fit.
thank you Grandad4. I will check fastline out right now.
   / I need to replace my JD2240 tractor #10
That a big 10-4. Speaking from experience i have gotten into big of hurry or let some salesman talk me into something I later regretted.
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
Mini Margaritaville Truck (A55853)
Mini...
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
2012 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
