I need horse help
/ I need horse help #1
Tractors4u
Elite Member
Athens Alabama
Deere 4310, Kubota L355, John Deere SST18 Spin Steer, 2006 Polaris Ranger
In June I moved into a friends house when he was activated by his National Guard unit and went to Afghanistan for 18 months. He has 4 horses I am taking care of. I can saddle the rideable horse and ride him, but I always have trouble with the bridle and I am not sure that I am getting it on correctly. Could someone please post a picture of a bridled horse for me to see? Thanks!
/ I need horse help #2
With a bit (it goes in the mouth) or without? Main strap straight up and behind the ears, one over the eyes around the forehead, and a buckled strap under the rear jawbone. Two reins back for the rider.
How about a pic of what you have? /forums/images/graemlins/wink.gif
I'd be real worried, if I was your friend. /forums/images/graemlins/grin.gif
Also, pics of bridles are in the 'related links' above these thread messages you can click on.
/ I need horse help
Maybe he will get back before I get deployed. Here is a picture of Tucker from this afternoon.
/ I need horse help #4
From what the dark photo shows....looks like you've got it right. I assume this is the same bridle that your deployed friend used? If not, stongly recommend you use what he/she used. The horse may no take too well to a different bridle, particularly if the bit is different (snaffle, split, bar, chain, etc.).
Thanks for caring for both our troops and their horses!
Dave
/ I need horse help #5
Brent,
It appears to be on right, the throat lash (strap under throat) may be a little tight. You should be able to get 4 fingers under this strap.
I am not sure that you should be riding a horse without some supervision though based on your question. But good luck and make sure you wear a motor bike helmet.
YEE HAA...!!!!!!!!!!!!!!!!!!!!!!!!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ I need horse help #7
I had a dark horse like that once, and her name was Shadow.
I had to brighten up the pic a bit, but it appears you are good to go and have it on right.
(pic attached)
/ I need horse help #8
I agree with Vin, the chin strap looks too tight.
Also, unless the picture happened to catch the horse's mouth in a funny position, the bit looks too tight, especially with the reins being slack. In other words, the bit looks like the reins are being pulled on.
/ I need horse help #9
Howdy Brent, Good for U! BTW, I echo all other post & looks like bridle is OK! Let me say this constructively(is that a word)! A horse is a very sensitive & intelligent animal that can fell fear or doubt in others! The horse probably feels uncertainty in u & is playing off that! Theres not enough room or time for someone to try telling u about horses on 1 message so I suggest U go to a search mode & find someone that does this and follow instructions, get magazines & read BUT MOST OF ALL, remmeber they are animals & don't take things for granted because U can(anyone/ the novice or the expert rider) can get hurt ! Boy a guy can get alot of advise by just asking if bridle looks right!!
/ I need horse help #10
MikePA
I think you are correct too, and the straps are adjusted too short.
Maybe this bridle is for a smaller horse of the 4.
/ I need horse help
Thanks for all of your help and the confirmation on the bridle. Since my friend left in June we haven't gotten to ride as much as we would like. Good point on using the same bridle he had used. This was another that he had in the garage. I hadn't thought about the ole boy being accustomed to one. Before he left he showed me how to saddle the horse but he had already put the bridle on so I missed that part of the lesson. I am comfortable around horses and they seem to be comfortable around us. They get feeding and brushing regularly. They recognize our John Deere Gator as "Meals on Wheels".
/ I need horse help #12
At first glance I thought Wow! You really have it too tight! His eyes are rolled back in his head! Then I realized that I was just seeing the reflection from the flash. /forums/images/graemlins/grin.gif
/ I need horse help #14
Brent,
As some others have said, the throat lach needs to be farily loose. You should be able to put 4 fingers side by side under there when it's adjusted correctly. The buckles on the cheek (side) straps should be adjusted so that there are 2-3 wrinkles at the corner of the mouth.
Also, I can't see well enough in the photo, but it doesn't look like there is a curb strap or chain on the bit. This is a leather or nylon strap or a chain with leather straps on the ends. It goes under the horses chin so that when you pull on the reins the bit pulls mostly down against the lower jaw.
Mike
KBH 1600 Gallon Water Trailer (A64047)
KBH 1600 Gallon...
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A63569)
BG PF5 HIGH OUTPUT...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
SET OF (9) CENTRIFUGAL PUMPS (A63569)
SET OF (9)...
John Deere 4040 Tractor (A64047)
John Deere 4040...
2007 TEREX ADVANCE MIXER FD3000 AWD 6X6 FRONT DISCHARGE MIXER (A59910)
2007 TEREX ADVANCE...
