I need bandsaw advice
/ I need bandsaw advice #1
MrJimi
Elite Member, Rest in Peace
NorthEast, Florida
Case 1845 C Skid steer
I am wanting to purchase a 7 X 12 saw and I have been looking at this one
Enco - Guaranteed Lowest Prices on Machinery, Measuring Tools, Cutting Tools and Shop Supplies
And here is another one
It has hydraulic down feed, auto shut off and liquid cooling.
My question is what are the good differences to look for, lots of saws fit this description and like everybody else, I want the best value for my dollar
Jim
/ I need bandsaw advice #2
MrJimi,
That is a pretty good little saw you are looking at. I had an older version of it many years ago. The key to any saw like that is the blade width and tooth configuration. This one uses a 3/4" blade. That is the minimum I would recommend. Try to get premium blades with variable tooth configuration, 3/6 or 6/10 staggered teeth and don't skimp there. They are what do the work. Make the blade match your work piece. Here is something I found describing tooth set.
Lenox saw Blades
The blade width is what gives you good sawing features for a straight and fast cut. Smaller blades tend to wander through the cut. I had several Wells saws in my business with 1-½" wide blades that would slice off .050" thick slices out of Ø6" bar stock in less than 1 minute. They had adjustable hydraulic down feed pressure. Of course they cost around $6,000 now. Now I have a JET saw in the garage just like that Enco you are looking at.
/ I need bandsaw advice #3
Afternoon Mr. Jimi,
As Rob stated not a bad little saw ! We use a larger Kalamazoo cut off saw at work and we use Lennox Blades almost exclusively. They are the best IMHO. Whether they are used for a cutoff saw, bandsaw or hole saws ! The little Enco you are looking at will do a descent job for its size without breaking the bank :)
BTW we use 4-6 TPI for general cutoff of most materials.
/ I need bandsaw advice #4
Well,
You could do what I just did...
I bought a bandsaw, used, halfway across the USA from here, for almost as much money, and I still have to get it here...
David from jax
It does have a blade welder on it, but not sure if it works. If it does, or can be fixed, we will be able to fix the cheap blades at least. The better blades are not cheap, and aren't always repairable.
I am going to take a week off and go get it after Thanksgiving.
David from jax
/ I need bandsaw advice #5
I have one like your second pic. It's a pretty decent saw, but on mine the blade will just not quite cut all the way through the work piece w/o me having to put a spacer under the material to lift it up an 1/8th of an inch or so. I don't know if this is a flaw in all of them or just my particular saw.
I've gotten my $700 bucks worth out of it though.
/ I need bandsaw advice #6
I purchased one just like that 4 years ago for the company I work for. It is used every day to cut many different types of metal, a lot of stainless steel.
The one thing you want to do is spend a little more on a good blade. We use a M-42 Cobalt blade. They stay sharper longer and cut the tough stuff with ease, also works good on aluminum.
The one we have has a coolant pump and I assume your's does too, use it it makes a world of difference in band life.
Many times I have cut pieces much bigger than it's rated capacity.
Randy
/ I need bandsaw advice #7
RedRocker,
You may want to visually inspect your saw to look for interference. Typical places is where the roller guides near the motor are hitting the bed frame? Same with the movable roller guides. It might be your stationary or movable clamping jaw? Since these are castings, they might be rough and some areas interfere. Also check your hydraulic cylinder to be sure it is not bottoming out when the saw goes down. Another place is the shut off switch. It can also be adjusted to a lower position.
I would check each place and adjust/repair as needed. Then try after each adjustment one at a time until you find the culprit. I'd be interested to see what you find.
/ I need bandsaw advice #8
Thanks Rob, it's one of those deals that was easier to deal with than try to fix. One of these days I'll tear in to it and see if I can fix the problem.
/ I need bandsaw advice #9
dollars to donuts it's the cut off switch adjustment, like Rob suggested. You'll kick yourself when you see how easy it is to adjust :)
/ I need bandsaw advice #10
I have a couple of bandsaws, a small Jet and an Ellis 1600. The Ellis is simply awesome and there are no coolant issues to deal with. I also get great blade life with the Lenox blades I use.
/ I need bandsaw advice #11
One thing to watch for is a roller bed that you can set up next to your saw. Set them up level with the saw and you won't have to worry about holding up long stuff while it is cutting. Plus gives you somewhere to lay the drops while your cutting the next item in your list of things to cut. One going in and one going out work even better if you have the space for them.
I have some extra roller beds, purchased from a trailer repair shop, used.
None are cheap, but these are close...
David from jax
/ I need bandsaw advice #12
sandman2234 said:
One thing to watch for is a roller bed that you can set up next to your saw. Set them up level with the saw and you won't have to worry about holding up long stuff while it is cutting. ...
Handy to the point of being indispensable for infeed and outfeed in a woodshop. I have some for almost every stationary tool in my shop. Google (or Froogle) "Roller Stand"
