mx842
Platinum Member
- Joined
- Feb 26, 2011
- Messages
- 916
- Location
- Richmond Va
- Tractor
- Kubota L3301, PowerKing 2414, John Deere 316, Gravely ZT HD 52
I have this mid 70's 2414 PowerKing tractor that seems to be losing tranny oil and at the same time it seems to be making gear oil in rear differential. Last summer I replaced all the fluids on this tractor and at that time everything looked ok other just being dirty.
Now fast forward about 15 months. It sat for several months because it had a flat front tire and I finally decided to put new ones on it. While I was working on it I decided to check the fluid levels and do a few other things I had been putting off. When I did the transmission was almost empty and the rear differential was about a pint over filled. My first thought was that a seal in the transmission went bad and the oil somehow ended up in the differential if that is even possible. I have the owners manual but that don't tell me much so I'm in search of some kind of repair manual so I can see what's going on.
The thing is the last time I used it there were no strange noises and the tranny shifted like it should. Hopefully it didn't hurt anything. I know sometimes machines will have what I call a cold leak meaning it doesn't leak when the fluid is warm or hot but will leak a little when the machine sits for awhile. Hopefully that is what's going on but I'm still having a hard time trying to figure out how the tranny oil was really low and the rear was way overfull. Is it even possible for this to happen?
