I-match and a carry-all
   / I-match and a carry-all #1
Piedmont
NC, USA
JD 2520
Does anyone have a carry-all attached with their I-match? Are all brands compatible?
   / I-match and a carry-all #3
For the TSC ones, just make sure it's made by Hawkline. They market under a few different names. I think the Hawlkine ones at TSC are Farm Force or soemthing like that. Take a tape measure. If the distance between the lift pins and top link pin (center to center) is 15" then you'll be good to go with the iMatch. I saw some that were 18" and 21" at TSC.
Thanks guys i appreciate your input!
   / I-match and a carry-all #5
I bought a Farm Force at Tractor Supply Co yesterday... it doesn't fit i-match. If I weld on a tube for the top link and get longer lower-link bolts, it would work. Not a direct-fit from the store, though...
   / I-match and a carry-all #6
I got mine from 3 POINT HITCH WELD UP CARRY-ALL KIT It is awesome ask for Bill Tell him you want made for Your JohnDeere Imatch The kit is awesome I built mine & yes Jd Green Paint it will hold 800 Lbs http://i182.photobucket.com/albums/x247/kvjohndeere/100_0778.jpg
http://i182.photobucket.com/albums/x247/kvjohndeere/100_0773.jpg
http://i182.photobucket.com/albums/x247/kvjohndeere/100_0771.jpg
http://i182.photobucket.com/albums/x247/kvjohndeere/100_0777.jpg
   / I-match and a carry-all #7
kvjohndeere said:
OK, KV, I give up. What are the upper set of pins for on your carry-all? I am having a hard time imagining when you would need those.
   / I-match and a carry-all #8
They are for your adjustments if you to make it lift higher if you did nt have an I match ! So it is very versatile Take care
   / I-match and a carry-all #9
... still don't get it!
Wouldn't using the higher set of pins have the effect of lowering the carry-all? Regardless of I-match or standard 3ph?
   / I-match and a carry-all #10
They put Different Pin on there for height reasons ! Im like you ! I t is a good Idea though ! They designed not me LOL ! I just bought the Kit ! & welded it up ! I guess if you had A bigger series tractor it would be handy !I mean A bigger tractor with higher lifting 3pt arms !
2015 Ford Transit 150 Cargo Van (A53422)
2015 Ford Transit...
2010 Ford Edge AWD SUV (A55758)
2010 Ford Edge AWD...
Mini Excavator Pallet Forks (A53316)
Mini Excavator...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2016 Peterbilt 567 Tri Axle Dump (A47477)
2016 Peterbilt 567...
