I-match and a carry-all
   / I-match and a carry-all #1
Piedmont
NC, USA
JD 2520
Does anyone have a carry-all attached with their I-match? Are all brands compatible?
   / I-match and a carry-all #3
For the TSC ones, just make sure it's made by Hawkline. They market under a few different names. I think the Hawlkine ones at TSC are Farm Force or soemthing like that. Take a tape measure. If the distance between the lift pins and top link pin (center to center) is 15" then you'll be good to go with the iMatch. I saw some that were 18" and 21" at TSC.
Thanks guys i appreciate your input!
   / I-match and a carry-all #5
I bought a Farm Force at Tractor Supply Co yesterday... it doesn't fit i-match. If I weld on a tube for the top link and get longer lower-link bolts, it would work. Not a direct-fit from the store, though...
   / I-match and a carry-all #6
I got mine from 3 POINT HITCH WELD UP CARRY-ALL KIT It is awesome ask for Bill Tell him you want made for Your JohnDeere Imatch The kit is awesome I built mine & yes Jd Green Paint it will hold 800 Lbs http://i182.photobucket.com/albums/x247/kvjohndeere/100_0778.jpg
http://i182.photobucket.com/albums/x247/kvjohndeere/100_0773.jpg
http://i182.photobucket.com/albums/x247/kvjohndeere/100_0771.jpg
http://i182.photobucket.com/albums/x247/kvjohndeere/100_0777.jpg
   / I-match and a carry-all #7
kvjohndeere said:
OK, KV, I give up. What are the upper set of pins for on your carry-all? I am having a hard time imagining when you would need those.
   / I-match and a carry-all #8
They are for your adjustments if you to make it lift higher if you did nt have an I match ! So it is very versatile Take care
   / I-match and a carry-all #9
... still don't get it!
Wouldn't using the higher set of pins have the effect of lowering the carry-all? Regardless of I-match or standard 3ph?
   / I-match and a carry-all #10
They put Different Pin on there for height reasons ! Im like you ! I t is a good Idea though ! They designed not me LOL ! I just bought the Kit ! & welded it up ! I guess if you had A bigger series tractor it would be handy !I mean A bigger tractor with higher lifting 3pt arms !
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
(2) SQUIRREL CAGE FANS (A54756)
(2) SQUIRREL CAGE...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A55788)
2016 Big Tex 14ft...
2013 Ford E350 Box Truck (A47477)
2013 Ford E350 Box...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
