I-match and a carry-all
   / I-match and a carry-all #1
Piedmont
NC, USA
JD 2520
Does anyone have a carry-all attached with their I-match? Are all brands compatible?
   / I-match and a carry-all #3
For the TSC ones, just make sure it's made by Hawkline. They market under a few different names. I think the Hawlkine ones at TSC are Farm Force or soemthing like that. Take a tape measure. If the distance between the lift pins and top link pin (center to center) is 15" then you'll be good to go with the iMatch. I saw some that were 18" and 21" at TSC.
Thanks guys i appreciate your input!
   / I-match and a carry-all #5
I bought a Farm Force at Tractor Supply Co yesterday... it doesn't fit i-match. If I weld on a tube for the top link and get longer lower-link bolts, it would work. Not a direct-fit from the store, though...
   / I-match and a carry-all #6
I got mine from 3 POINT HITCH WELD UP CARRY-ALL KIT It is awesome ask for Bill Tell him you want made for Your JohnDeere Imatch The kit is awesome I built mine & yes Jd Green Paint it will hold 800 Lbs http://i182.photobucket.com/albums/x247/kvjohndeere/100_0778.jpg
http://i182.photobucket.com/albums/x247/kvjohndeere/100_0773.jpg
http://i182.photobucket.com/albums/x247/kvjohndeere/100_0771.jpg
http://i182.photobucket.com/albums/x247/kvjohndeere/100_0777.jpg
   / I-match and a carry-all #7
kvjohndeere said:
OK, KV, I give up. What are the upper set of pins for on your carry-all? I am having a hard time imagining when you would need those.
   / I-match and a carry-all #8
They are for your adjustments if you to make it lift higher if you did nt have an I match ! So it is very versatile Take care
   / I-match and a carry-all #9
... still don't get it!
Wouldn't using the higher set of pins have the effect of lowering the carry-all? Regardless of I-match or standard 3ph?
   / I-match and a carry-all #10
They put Different Pin on there for height reasons ! Im like you ! I t is a good Idea though ! They designed not me LOL ! I just bought the Kit ! & welded it up ! I guess if you had A bigger series tractor it would be handy !I mean A bigger tractor with higher lifting 3pt arms !
2019 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A55788)
2019 Dodge Ram...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A55301)
2008 Ford F-250...
2003 Ford E-450 16FT Reefer Box Truck (A55788)
2003 Ford E-450...
CRAFTSMAN TABLE SAW (A54756)
CRAFTSMAN TABLE...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55302)
2020 New Holland...
