I keep breaking 1/2 ratchets on my lug nuts.
   / I keep breaking 1/2 ratchets on my lug nuts. #31
Every time I rotate tires or have them off for any reason. Hand start lug nuts, run them up with impact, tap them a couple times, then finish with torque wrench
Same. I've also taken to leaving the torque wrench laying out on the garage counter, as a reminder to re-check them after driving the car the next day. Most stay right on the money, but sometimes you find one that "seated in" a bit after that first day's driving.
I briefly owned a truck with Ø40" x 17" tires on 5-lug wheels, not my doing, the prior owner configured it that way. What I learned from that experience was that the actual level of torque was much less important than evenness of torque. Put otherwise, I could tighten the ever-loving crap out of those lugs by hand, and they'd still work loose over time, if not all even. But if I used a torque wrench and got them all even, even at a lower torque, they'd never work loose. That was an eye-opener for me, in always using a torque wrench, given the speeds I like to travel on the expressway.
   / I keep breaking 1/2 ratchets on my lug nuts. #32
Just to make sure it is clear, a Torque Wrench is not the same thing as a Torque Multiplier.
A Torque Wrench is used to make sure that a bolt is as tight as you are supposed to have it, and a Torque Multiplier is used to loosen nuts and bolts that are too tight to get loose without breaking your ratchet or having to use an extension to increase the force. A Torque Multiplier uses a planetary gear system to use a smaller force to increase the torque to loosen a nut.
David from jax
   / I keep breaking 1/2 ratchets on my lug nuts. #33
There was a time I used to run them in with a impact and said good enough. Driving to work one night the valve stem extender came loose and broke the valve on the inside dual. Because it was fieldwork season had everything with me including at that time Craftsman 1/2" impact. Pulled off, jacked up the truck changed tire, and ran all the lug nuts and hammered away. Still got to work before start time. 2 weeks later truck acted funny on corners. Got to the field and realized the dual I changed had worked loose. From that day on made sure always torqued to specs.
I don't double check though and that would be a good practice to get into.
   / I keep breaking 1/2 ratchets on my lug nuts. #35
There is a lot of talk about your personal torque wrenches on this thread. Nobody has mentioned this important detail on click type torque wrenches besides the calibration note. After use the torque wrench needs to be backed off from it's torque value. My Proto .50 micrometer torque needs to be backed off to 50 ft./lbs. My .38 Proto goes back to 20 ft./lbs. Leaving the spring mechanism compressed at some value higher value shortens the life of the calibration. Another note from years ago work, on a freshly torqued fastener it takes approximately 20% less torque for breakaway. Another note from previous years is that a deflecting beam type torque is the most accurate of torque wrenches. I don't have the exact details but from work we did again years ago a click style torque is more accurate in the mid to upper range of the torque wrench.
   / I keep breaking 1/2 ratchets on my lug nuts. #36
If the owner of the torque wrench bothered to read the enclosed instructions that came with it, it plainly states all the criteria of operation in that manual... Of course most people never bother reading instructions and that also applies to tractors and vehicles in general. Far as torque wrenches are concerned, storing one in whatever 'relaxed' position is entirely up to what type of wrench it is. Never used a torque multiplier to remove any lug nuts or anything else for that matter and that includes 10 hole Bud style big truck wheels. I use an air powered impact wrench of sufficient capacity to remove them and I always use a torque wrench to remount them.
One thing most people don't realize is that when mounting any wheel to a spindle, it has to be torqued properly or the mounting studs can be stretched or the 'coined' mounting holes (in the case of steel wheels) can be deformed and the wheel can become detached in use.
Most if not all owners manuals will state the correct prevailing torque for mounting.
   / I keep breaking 1/2 ratchets on my lug nuts. #37
The issue with using an air powered impact wrench of sufficient capacity...is you can't carry that out to the field where you have a flat tire. Most people don't even have the air capacity to run a one inch drive impact, much less own an impact of that size. The new battery powered impacts are appoaching the capacity needed to remove such a lugnut, but not quite there yet.
My Snap-On Torque Multiplier is rated at 2000 pounds of torque, and can be carried in one hand out to where the tractor is. The fact that you have never used one means you should probably just refrain from addressing that subject, not sticking in your $.02 worth to tell us what is so much better because that is the way you do it. Most people don't have the need for the elaborate setup needed to change semi trailer tires. A Torque Multiplier won't have a battery life, or require a huge compressor to run it.
David from jax
   / I keep breaking 1/2 ratchets on my lug nuts. #38
Not to start a whole other tangent, but I can't blame people, here. I own a lot of vintage tools and associated paperwork, and manuals used to be condensed down to a very few and very useful pages, always worth a read. But today's tools and vehicles come with manuals that are usually 50% to 80% full of useless warnings for scenarios I couldn't even imagine being a problem for any reasonable person, to the point where it's difficult to even find the actual useful content, assuming it hasn't been removed or truncated in favor of more legalese.
   / I keep breaking 1/2 ratchets on my lug nuts. #39
I looked into this years ago, and the break-out force on most of the better 1/2" ratchets seemed to be around 500 ft-lb. I don't know what 1/2" breaker bars are rated to handle, but spent much of my late teens and early 20's bouncing and jumping on the end of a 4' pipe extension slipped over the handle of mine, and it never broke (back then... it has since).
I will say that I've seen Craftsman ratchets break more than all other brands combined. But then again, back when I was spending all my free hours wrenching on cars (1990's), Craftsman also sold more ratchets than probably all other brands combined. I've also seen a few broken Snap-On ratchets, but oddly, never a broken vintage Proto.
The vintage Proto ratchets make a good hammer too, they're a bit large in the hand by today's standards. But if you're in the habit of breaking ratchets, and don't mind their larger head size, that may be the brand for you. I don't know if their new stuff is any good, they're owned by Stanley now, but their original 1960's hardware made out of their Los Angeles plant was bullet-proof.
The only Craftsman ratchets I own today are two ratcheting clicker-type torque wrenches. They don't get used hard, so they haven't failed. All of the other Craftsman ratchets I have ever owned broke, and were tossed in the garbage.
I've never used, probably never even seen, a Harbor Freight ratchet. But you also couldn't pay me to use one. I'm not that cheap, and I like the skin to remain on my knuckles as much as possible.
I like the SK (Wayne) triple tooth contact Pro ratchets as far as ratchets go, they have held up and if I was at a dismantling yard and all I had was a short cheater bar and that socket set that is what got abused. For stuck lug nuts and a few stubborn axle nuts or hydraulic cylinder rod/piston nuts, I try with a 3/4" breaker bar set up or the Aircat 1/2"impact, then bought a 1" Vevor "advertised" 4280 ft lb. air Impact for when that fails and 'so far' it has worked when everything else failed, but I need to add a reserve air tank with large lines to make it work at full power. Supposed to have 175 psi it does but still need 1/2" air lines for the tool use volume. it is an absolute air pig and at almost 50lb is a pain to use.
I was sold after the comment about easily breaking the piston rod nut loose on a 325 CAT Excavator boom cylinder
   / I keep breaking 1/2 ratchets on my lug nuts. #40
No issue with me at all but... Torque wrenches, in order for them to retain their accuracy, must be stored in a 'relaxed' position and that position varies by construction.
My 2 requirements for any torque wrench is 1. It must indicate torque in both directions, that is tightening torque and loosening torque or should I say left hand torque as in left hand threaded nuts and 2. It must come with a certification document and be easy to calibrate. The HF Icon torque wrenches check those boxes for me.
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
RoGator RG1100C (A55302)
RoGator RG1100C...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
CATERPILLAR 307E2 EXCAVATOR (A52705)
CATERPILLAR 307E2...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A55787)
2018 Bobcat T590...
