I just bought an Echo 2511t clone for $99. What was I thinking?
   / I just bought an Echo 2511t clone for $99. What was I thinking? #421
Do you know if the G2500 and the G2511 have the same motor, looking to upgrade to the NGK CMR7H plug that some folks are running.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #422
Well, I've used this little top handle clown saw a bit since it arrived, and the only real fault I find is that the tank fill cap retainers bind inside the tanks and make refitting the caps a royal PIA.
So, I cut them off.
I'll let you know when having a loose cap cuts into the serenity of my day. ;-)
   / I just bought an Echo 2511t clone for $99. What was I thinking? #423
Can you post a picture of what you cut off?
   / I just bought an Echo 2511t clone for $99. What was I thinking? #424
Not same motors at all. 2500 is a zenoah clone.
Let me check what plug I had in mine before traded it off.
You are asking about G2500 right?
   / I just bought an Echo 2511t clone for $99. What was I thinking? #425
@Hds2561 If asking about G2500. Double check me and pull your plug and see what afm plug they show too.
Straight from Zenoah 2500 IPL. I will link their partslist here for ya too.
RCJ7Y and several ngk plugs that will cross reference to that.
  • ZENOAH-G2500.pdf
   / I just bought an Echo 2511t clone for $99. What was I thinking? #426
Sounds like he cut the plastic retainer that goes inside the tanks off the caps.
I never had a issue with that since 2023 using first one now with oem or afm caps.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #427
Wow, I've never had an issue with mine binding but I can see that they might. My stihl all use a string that is very flexible.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #428
I have the JohnCutter and the V-Modest versions, both bought this summer from Hockfire Saws in Ohio, they can be found on Facebook and he ships to you with NGK plugs, he tunes them, and he can toss in extra chains for a fair price. I will say that I like the JohnCutter better, the V-Modest runs just as well, but I have an issue with the debris shield from the top, under the handle rattles off in seconds. It just does not fit correctly. The JohnCutter is tight and right.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #429
If you go back one page, you will see Hockfire saws has been posting in this thread. :)
   / I just bought an Echo 2511t clone for $99. What was I thinking? #430
Yes I was asking for the NGK cross reference plug that will work in the G2500 saw. The plug that it was shipped with is a CDK plug and the number is L7TC.
2006 Mac Truck CXN613 (A56438)
2006 Mac Truck...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
12ft. Flatbed Truck Body (A59230)
12ft. Flatbed...
2022 John Deere R4023 (A60462)
2022 John Deere...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
