I just bought an Echo 2511t clone for $99. What was I thinking?
   / I just bought an Echo 2511t clone for $99. What was I thinking? #251
Don't you need 44 drive links, not 45? These look like semi-chisel.
bar stamped 45. Just went to Echo site for the 2511T. list 91PXL45CQ for 12" bar. Oregon chain finder shows 45 DL also for Echo. Amazon list chain as full chisel but maybe semi-chisel. Either wouls be ok with me as long as they do ok. For 21.50 for 3 not going to complain
   / I just bought an Echo 2511t clone for $99. What was I thinking? #252
Just went and looked at my Echo 2620 pole saw. 12" bar also but it takes a 44DL chain instead of a 45 like the 2511. 1 link difference, not sure reasoning on that
   / I just bought an Echo 2511t clone for $99. What was I thinking? #253
Echo 2511PN OEM. Egan pipe was way ahead of rest. PSS V2 was next and reminded me of the egan in acting and sound etc. WSC was last on the OEM. Only one it would have beat was the stuffed up OEM stock muffler.
So on clone farmertec 2511 I only tested the open clone muffler with small pipe and compared to egan pipe to see.
Egan on clone was 2.3sec per cut faster the the open clone muffler with smaller pipe.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #255
The Egan is super snappy!
I'll prob put the Egan back on OEM.
Put the PSS V2 on the Farmertec clone and test it out.
Should beat the clone open muffler being it is 6.4mm bigger outlet then clone open muffler.
This is what came with my Joncutter
   / I just bought an Echo 2511t clone for $99. What was I thinking? #258
The Joncutter G2511 I bought from Az came with that same box and says the same thing on the plastic bag. The technical data in the owner's manual does not list the number of drive links. The bar is printed HYA-45-509P.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #259
Couldn't stand it anymore. Went and pulled chain off and counted drive links. 44, bar stamped 45. Now what? Maybe I should send chains with 45 back and get 44. This very confusing with bar stamped with a 45 on it but knew my 12" pole saw uses a 44. Maybe some of you saw guys can wade in here and give expert advise.
   / I just bought an Echo 2511t clone for $99. What was I thinking? #260
This thread got me to go to Amazon, I found a 1222cc G888 Gasoline Chain Saw Power Head Sprocket Nose 7 tooth 404'' Pitch Compatible With MS880 088 Chainsaw for $607!!
Do you think the 1222cc is a typo? :)
2014 Allen Engineering ACM9PH 9 Yard S/A Towable Concrete Mixer (A55973)
2014 Allen...
EXCAVATOR JACKHAMMER (A58216)
EXCAVATOR...
JLG 660SJ (A58216)
JLG 660SJ (A58216)
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2021 Ford F-450 4x4 Crew Cab Venturo ET12 1.5 Ton Crane Service Truck (A55973)
2021 Ford F-450...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
