I have owned my last 2 wheel drive pickup
/ I have owned my last 2 wheel drive pickup #201
You will have to research that. Find out which axle is in your truck, and then check on line to see if a locker is available for it. Or - if you have a trustworthy shop nearby, have them check to see which axle is under your truck. The same model truck can have several different axles depending on when it was built and how it was spec'd out. I know my F150 had two different axles available when I bought it. There is usually a tag on the rear differential cover, or some numbers stamped there or on the axle tube, that tells you the model of the axle and what gear ratio it has.
If there is a locker made for your particular axle then there is no reason why that locker can't be installed...other than the cost.
There is a truck customs shop nearby that I am familiar with - my buddy owns it, and he is exceptionally skilled and knowledgeable. I'll discuss with him next week when I see him. Thanks for the tips. That is all new to me.
/ I have owned my last 2 wheel drive pickup #203
That looks like a case of street tread tires and no lockers. Tires that are nice and quiet on the road and on wet pavement conditions are never any good in wet grass and mud. A better all-terrain or even better a mud tire and lockers front and rear and you would probably just drove out of that situation, well if you locked the lockers prior to spinning and digging in too deep. :)
Nope....duratrac tires, rear axle locked, all four tires spinning.
The far side of the truck was more sunk than that picture implies.
That trailer also had two yards of dirt in it when I got stuck and it sunk pretty good. Going forwards is up a hill and it just wouldn't go once it found the mud.
Can sorta see the tires and normal height of the truck here.
/ I have owned my last 2 wheel drive pickup #204
Personally I don't think a locker will make much difference on WET ground or soft ground. They work awesome for some things and are better than nothing but I imagine stuck will be stuck 99% of the time in a 2wd with the rear axle locked or open.
You should be able to look at the RPO codes (potentially in the glove box) or a Vin decoder online to see what rear axle you have. There are many different styles of lockers out there and likely one for your truck.
/ I have owned my last 2 wheel drive pickup #205
Scaredychicken,
This link goes to a PDF file that shows everything your truck was available with.
Page 13 shows all the different axle options that were available.
Page 16 shows all of the RPO codes for the options.
In the left column, you can see the different axle ratios and the code G80. That's for the rear axle locking differential option.
If you open the glovebox, there should be a label with all of the RPO codes that your truck came with. If you see G80 among those codes on your sticker, you already have a locking differential from the factory. If you do not see that G80, then you don't (from the factory).
For example, my 2003 Suburban's label. It shows RPO code G80. That's an automatic locking differential (circled in red).
/ I have owned my last 2 wheel drive pickup #206
Also, if you look at my codes, just before G80 is G65, self-leveling shock absorbers that are about $400 EACH! :eek:. And GT4, which indicates 3.73 rear axle ratio.
There's all kinds of stuff you can figure out from the RPO codes on that label.
It's really interesting and kind of handy to take a picture of that label and then use google to find out what each code means, and write it down for future use.
/ I have owned my last 2 wheel drive pickup #207
The G80 won't lock at over 20 MPH. My Colorado is equipped with that and while it does help, I still couldn't go very far this time of year without 4WD.
/ I have owned my last 2 wheel drive pickup #208
He has a Ford F-150, not a GM. It won't have a g80 locker
/ I have owned my last 2 wheel drive pickup #209
Moss and I were referencing this:
I have a '93 Silverado C2500 Z71 that I bought seven years ago for $2500. It is low Kms, and in great shape, it owes me nothing. I can't even think about replacing it yet (we have a 4x4 SUV for most winter driving). Rarely do I get stuck, but it has happened. I am in the process of buying new tires for it ... All Terrain, 10 ply, Light Truck knobby tires, rated for every season. That alone should be a significant improvement, on the almost 20 yr old all-season tires that are on it now. The Old Body Style (OBS) trucks are retaining their value at this point, so I will hang on to it for now.
I also have a project truck (son hit a deer / tree), that I plan on repairing and returning to the road ... 2004 Mazda B4000, 4x4, 4L, v6, in otherwise good condition.
not sure what you mean by "installing a locker" ? I'd like to look into that. Thanks for any other details that you may have.
although it appears that he is referring to something other than his Z71.
/ I have owned my last 2 wheel drive pickup #210
I am under the impression that the G80 option differential will lock anytime one of the axle speeds exceeds the other by 120rpm. It has no way to determine actual MPH.
/ I have owned my last 2 wheel drive pickup #211
I was referring to scardychicken's Chevy Silverado. Maybe he was talking about his Mazda project truck? Anyhow, sorry for any confusion. (y)
/ I have owned my last 2 wheel drive pickup #212
I was also, until I started reading up on them. Members of several off road sites have mentioned it in the course of various discussions.
/ I have owned my last 2 wheel drive pickup #213
Yes. I read some of that as well. Generally, it looks like they like the auto-locking hubs for most situations. But there are some where you'd like to lock the hub manually BEFORE going into a situation, or have it stay locked in DURING a situation. GM's auto-locker won't do that. It'll only engage if you start spinning one rear tire 120rpm faster than the other and disengages by itself.
On the plus side, you can't forget to turn it off.
/ I have owned my last 2 wheel drive pickup #214
10 years ago, Ford had the best hub set up automatic with manual over ride, just in case. My last Ford was an 08, I dont know what they have now.
/ I have owned my last 2 wheel drive pickup #215
I believe the biggest reason they kick out at 20mph is do that if one tire breaks loose at higher speeds, the other won't take over and send you around in a circle. Kind if like that SUV you posted a couple of days ago.
/ I have owned my last 2 wheel drive pickup #216
I went from
89 Dodge w150 4wd 15years 243k short bed best truck I ever had.
2004 Tundra double cab 4wd beutiful smoother than a caddie but way too thirsty, the only truck I ever traded at 37k
2007 Tacoma access cab 2wd, nervous in winter?? put Nokian Hakkapeliitta Tires and 290#s of steel plate in bed. No slipping at stop signs, no anti lock brake activation, I can take ramps at 45mph during snow storms. Now if I go off the road i will not be able to come back through a snow bank with 2wd but I find with these tires and the low stance of my truck, the stability is amazing. I ended up puting these on the wifes minivan and the son's Corolla. It's like night and day. BUT with out the wieght and tires I go nowhere in the snow.
2015 Tacoma Access cab same setup
These tires will improve your vans traction 75% with some wieght added. The winter compound goes all the way thru the thread unlike some other brands that only have the winter compound half way down and then the ALL SEASON compound starts. This does make a difference. I do not work for the company but I have been happy with every set I have purchased. You cannot run these in warm weather though, winter use only for the ones I buy.
We have Hakkas on the Sprinter van.
And 4Runner.
And Prius V.
/ I have owned my last 2 wheel drive pickup #218
Looks like a modern version of the old directional tread snow tires I ran in the 80’s
/ I have owned my last 2 wheel drive pickup #219
I've actually been reading up on the G80 quite a bit, as I would like to stop running my Colorado full time and make it more of an offroad truck for when I need it. Tonight instead of shifting into 4WD on the icy hill before my house I shut off the TC, to see if it would make the hill with just the rear differential locked. I made it about 2/3 of the way up the hill before the truck stopped. Shifting into 4WD I was able to go from a dead stop and continue up the hill. Had I been able to manually lock the rears it may have been different, as I would have been going faster than 20MPH while going up the hill.
/ I have owned my last 2 wheel drive pickup #220
Could be. I just can't find any literature that says they kick out at 20.
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
Kubota BX25D (A53317)
2012 TAKEUCHI TL12 SKID STEER (A60429)
2012 TAKEUCHI TL12...
2020 CATERPILLAR D1 LGP CRAWLER DOZER (A60429)
2020 CATERPILLAR...
