- Joined
- Aug 31, 2001
- Messages
- 65,962
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
But a lot of 2wd SUVs. Which is just weird.Now it’s rare to see a 2wd truck
Us mountain folks would consider your tilted ground to be flat.I live in the Midwest and have plenty of "tilted" ground....![]()
Very true. That’s why it’s best to own valley land in the mountains.Yep and us Midwest folks would consider your mountain ground hard to farm.![]()
That looks like a case of street tread tires and no lockers. Tires that are nice and quiet on the road and on wet pavement conditions are never any good in wet grass and mud. A better all-terrain or even better a mud tire and lockers front and rear and you would probably just drove out of that situation, well if you locked the lockers prior to spinning and digging in too deep.I couldn't have a 2wd truck as I manage to get my 4x4 stuck from time to time.
Steering is all well and good, and ABS allows you to choose what you want to hit. Personally, I prefer to stop before that happens. Even your owner’s manual says that it can lengthen your stopping distance. The only time that I slam on the brakes and do white knuckle steering is because the damned brakes won’t work. Sometimes in snow you do need to drag them a bit, so that the tires can cut through the snow to something more solid. I was well accustomed to pumping the brakes, and/or applying them until they just started to break loose, then back off. For a time I used the same tactics, backing off the brakes just before the ABS engaged. I was a long time breaking myself of that habit.The thing about ABS is you can steer.
