I got a dump truck! How does it work?
   / I got a dump truck! How does it work?
Is there any reason that you can't (won't) ask the owner??
I got it sorted out. I had just gotten it and was heading out for vacation with the family. I didn't want to call late and i figured this would be fun for the forum.
Owner is sending a mechanic to diagnose the issue of the bed only raising part way. I hope it's just low on fluid. But i wont be home until late tomorrow so i can't check.
   / I got a dump truck! How does it work? #22
I haven't seen one of those for years. The box on the floor is a control valve for a hydraulic spreader control. The spreader would slide into the dump body and connect through the valve body to a hydraulic pump mounted on the engine. The knobs control an auger belt that feeds material to a spinner at the rear. Spinner speed controls the throw of the material. The lever turns it on and off, down was on. There was an accessory box that wired up to a speed sensor and controlled the material feed according to vehicle speed. Pretty advanced for the day. You may still find some hydraulic lines running along the truck frame out to the back. We had a few of these contracted to the state to spread sand and salt on icy winter roads. During the summer they could be used to spread lime or fertilizer on farm fields. The 2 knobs under the dash would be for the dump body, one engages the PTO mounted on the side of the transmission and the other connects to a hydraulic valve to raise and lower the dump body. Like I said, that was 30+ years since I built and operated these.
The two knobs on the dash are the ones you want. The one on the floor is spreader control valve for a sander. The one knob that say PTO is your power take off .Push in the clutch ,pull it out to engage the transmission to pto MAKE SURE YOU ARE IN NEUTRAL!! The other knob should raise and lower the dump box.
   / I got a dump truck! How does it work? #23
Usually if not always you need a special Air Brake License to operate that vehicle on public highways.
   / I got a dump truck! How does it work? #24
Probably the same reason you and several others didn't read the thread before responding and see that he already figured it out last week and on page one no less. :ROFLMAO:
   / I got a dump truck! How does it work? #25
That was my first thought when I started to read this. The most logical solution 99% of the time. I am glad that was answered in a later post.
   / I got a dump truck! How does it work? #26
You can rent new dump trailers that will lay down driveway rock.
   / I got a dump truck! How does it work? #27
What are you hauling?
Spreading or dumping?
Private property or open road?
Watch some Youtube videos
Watch out for power lines
Last comment about the power lines - seriously true. Last week a driver of a dump truck got into a powerline 7 miles from here. Truck's trailer caught on fire and burned up . He's alive but will need skin grafts and in hospital for a month they say. If it happens , don't touch ground and vehicle at the same time as you exit. just jump out avoiding wires of course. Dump truck driver airlifted to UMMC with severe burns after hitting power line
   / I got a dump truck! How does it work? #28
what is posted is good information, My first question is whoever you bought this from, did they not know how to operate the dump?
   / I got a dump truck! How does it work? #29
Not really true blue hairs and munchkins drive All Over in pusher RV's with air brakes can barely see over steering wheel an the cars all have missing mirrors and ripples down both sides with white paint.
True about dump altho to truly understand drivers license req. GVW of dump needed.
I remember cdl cl A&B(3, 2 [bus] & 1)
All need air endorsements because of vehicle weights.
So I guess my point is if Ur worried about on road driving Research Ur states require.
As for ½ way dumping, could be low fluid, TOO MUCH weight or something in the way of pivot point.
   / I got a dump truck! How does it work? #31
Without reading through the whole thread, I'd like to ask the question;
If you are, borrowing, the truck, what did the owner tell about the truck's operation when you borrowed it?
   / I got a dump truck! How does it work? #32
If you don't know any more about this truck than you say, get somebody that knows how to drive and operate a dump truck to show you first hand how and how not to. Some good advice on this forum, some advice very questionable but probably all mean well. Somebody could get hurt or killed from what you are about to do. Don't be stupid and think anybody can operate a dump truck.
   / I got a dump truck! How does it work? #33
Difficult is PTO. Likely it won't engage well when nothing is moving, or when moving fast. Lots of variety in these. My last truck; low low, ease the clutch just enough to move the vehicle 1/4 inch, If cable actuated, it'll mesh.
My present truck low, ease off the brake just enough to feel a hint of motion. Once engaged, neutral & pull the valve lever to hoist.
   / I got a dump truck! How does it work? #34
The knobs under the dash are for the dump bed. The right knob is marked PTO. With transmission in neutral, and clutch disengaged while stopped, pull the knob on the right out. That will engage the PTO. Let out on the clutch, normally, pulling out on the left knob will raise the bed. If you are just dumping in a pile, pull the left knob out, and it will power up. Once it reaches maximum height, push knob halfway in for the hold position if you want to pull away from the pile, and completely empty the bed.
More than likely, it has power down too. If like mine on level ground, it raises pretty high and you'll need to power down some by pushing in the left knob until it stops, until gravity takes over. At that point, you can push in on the clutch, and push the PTO knob in. When the bed sets on the frame, pull the left knob back out to the middle position. The middle position should also be a hold position on the bed, if say you want to raise the bed half way.
If you want to tailgate stone, being it is a straight 5 speed ( not seeing a 2 speed rear end button or cable on the shifter ) it's probably geared low enough to take off and spread in 2nd. gear. Unless it's an air gate, the tailgate trip lever, if it has one should have a light piece of chain with a large loop on the end to put over the trip lever to keep it in place. There should also be a piece of rope on the trip lever. The trip lever should have a light snap to it going over center when the gate is latched shut. If it's worn as much as I think it might be, and it hasn't been adjusted up for wear over the years it probably won't take much to trip the gate.
Some manufacturers weld a little loop on the trip lever handles to hook a rope on using snap like on a lead rope. Or, have a hole in the handle to put a rope through. If you're planning on tailgating stone, you'll want a piece or rope, preferably soft nylon 3/8" rope approx. 36" long with a 6" or so loop on the end you'll be pulling with. This is extremely handy when tailgating stone.
If tailgating stone you'll want to set the chains so the gate opens, minimum 2X as wide as the stone you're spreading. You'll have to experiment with it depending on how thick you want to stone. Putting down a thicker base, or just top dressing. While setting still, raise the bed about 1/3 of the way up to make sure you have stone against the tailgate. If it will take off in second gear with a load on before trying to tailgate, place in second gear and get moving before pulling the trip lever. If you trip the lever before moving, you'll have a pile of stone you'll need to knockdown. Depending on how good you are on the clutch, if tripping from a dead dig it's been known to kill the engine and will be dumping stone in a pile until you get it restarted and moving. It's a learning curve if you've never done it before. More than likely, once you start moving you won't be able to change gears, due to gear pressure on the transmission with the PTO engaged. You'll just have to watch in the mirror and see how thick the stone is being put down and adjust speed from there.
The controls on the floor with dials and lever are for a salt/cinder spreader. If the PTO is engaged DO NOT mess with that lever. Just make sure it is in the off position and leave it there and set both dials to "0". If the lever is set in the engaged position with no spreader on, there's a good change pressure will deadhead against the pump and burst a hydraulic hose that goes more than likely from that control to the back of the truck, inside the frame. Not good if you have a load on and have to shovel it off until that hose gets repaired. That truck appears to be an 80's model, and a good chance the hoses are original.
Always be aware of tree limbs, power/telephone lines overhead when dumping, or especially tailgating. On a truck that size, the bed will easily raise above the 13'-6" legal height, but most residence lines aren't normally that high. It's not rocket science, just takes some common sense. Always be aware of what is overhead, and your surroundings.
Great info, thanx for your effort !!
Ok now help me with the dump issue. Plenty of oil and no noticable leaks.
   / I got a dump truck! How does it work? #36
Needs hyd oil...
Ok. I just made a discovery. This thing has a big hydro reservoir and it is full. But, and that's a big but, it's plumbed into the spreader circut not the dump circut. The dump circut is closed. I just gotta figure out how to get oil into that circut and i think it will work.
   / I got a dump truck! How does it work? #38
On the top of the hyd piston between the piston and floor near the rod end there's a cap you need a hand pump to get the oil in a funnel makes a mess.
   / I got a dump truck! How does it work? #39
I pumped all the oil out by the time i figured it out. Now there is 0 lift. I think i can feel the plug but there is no room to figure out how to open the plug much less get a tool in there to open it. Any ideas?
Caterpillar 279-5360 72in Dual Cylinder Grapple Rake Skid Steer Attachment (A59228)
Caterpillar...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2377 (A60432)
2377 (A60432)
