I Give Up! Buying Chains for my Kioti RX7320 Cab Tractor
   / I Give Up! Buying Chains for my Kioti RX7320 Cab Tractor #31
1. All vehicles are ice challenged, not just tractors.
2. All chains can be a hassle to install. You have to figure out which install method works best for you. On mine I put the tractor in neutral, jack up the rear, lift a chain up and onto the R4 lugs then rotate the tire around to pull the chain around. Then I can connect the inside and outside of the chain. .......
I do the same method. Just remember that not only do you have to put it in neutral, you also have to take it out of 4WD! Or else you'll be standing there asking: "WTF Man? Why doesn't that tire turn!!? Dooh!!"
Don't ask me how I know!! :mur: :D
   / I Give Up! Buying Chains for my Kioti RX7320 Cab Tractor #32
I had heavy duty tractor V-bar ladder chains when I had my Ford 1700. Front & rear. They were HEAVY which didn't help with the install. However, once they were on - I could climb a vertical wall. They made the Ford ride like a COB.
Were I to do it again. Definitely some type of the European chain with a better ride. I would have definitely given up some of the traction gained for a better ride.
And fortunately, you would not need to give up traction for better ride. Having run both styles on my tractor, the euro-style chains definitely have better traction.
E-Z TRAIL S10 GRAIN CART (A52708)
E-Z TRAIL S10...
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
2006 Chevrolet Express 3500 Versalift Vantel29N 29ft Bucket Van (A56858)
2006 Chevrolet...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
