I Give Up! Buying Chains for my Kioti RX7320 Cab Tractor
   / I Give Up! Buying Chains for my Kioti RX7320 Cab Tractor #31
1. All vehicles are ice challenged, not just tractors.
2. All chains can be a hassle to install. You have to figure out which install method works best for you. On mine I put the tractor in neutral, jack up the rear, lift a chain up and onto the R4 lugs then rotate the tire around to pull the chain around. Then I can connect the inside and outside of the chain. .......
I do the same method. Just remember that not only do you have to put it in neutral, you also have to take it out of 4WD! Or else you'll be standing there asking: "WTF Man? Why doesn't that tire turn!!? Dooh!!"
Don't ask me how I know!! :mur: :D
   / I Give Up! Buying Chains for my Kioti RX7320 Cab Tractor #32
I had heavy duty tractor V-bar ladder chains when I had my Ford 1700. Front & rear. They were HEAVY which didn't help with the install. However, once they were on - I could climb a vertical wall. They made the Ford ride like a COB.
Were I to do it again. Definitely some type of the European chain with a better ride. I would have definitely given up some of the traction gained for a better ride.
And fortunately, you would not need to give up traction for better ride. Having run both styles on my tractor, the euro-style chains definitely have better traction.
David White Meridan LT6-900 Level Transit, S/N D94224 (A59076)
David White...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
Informational Lot - Shipping (A56436)
Informational Lot...
MASSAGE CHAIR (A58214)
2001 KENWORTH T800 BOBTAIL KILL TRUCK (A58214)
2001 KENWORTH T800...
BOX OF BINDERS & MISC (A52708)
BOX OF BINDERS &...
