I changed my mind
/ I changed my mind #1
jcmseven
western NC
JD 2320; 4520
Fellow Posters,
About two months ago, I posted some pictures of my new Gator XUV. I also espoused the benefits of the gasoline engine v. the diesel and that I thought the gas engine would offer equal performance for less money. After using the Gator, which had been modified to achieve more speed, for several weeks, I turned it in on a new diesel XUV. My friend modified it the same as the other Gator, except we went with the soft top this time and went with the synthetic cord winch (nice). The diesel top speed is about 5-6 mph slower than the gas (about 35 mph, due entirely to the larger wheels) but the difference in torque is impressive. I would like to correct any advice I gave to the group based on my testing of both machines earlier. Since I have brought the diesel to my hilly environs, it really seems much stronger. With the larger tires to tap into the extra torque, this thing will really pull. Just wanted to pass this on to anyone who was on the fence between the two that my original opinion might have been incorrect.
John M
/ I changed my mind #2
I got my XUV850D a month or so ago and I can say I'm more then pleased with it. Big difference from my 05 HPX Diesel. So much smoother riding with the IRS (independant rear suspension) and much faster. I have hauled some heavy loads of dirt up a grade and the diesel just grins. Power dump bed was a good addition once you get the load to were you are going.
I know I'm using it more than the HPX. The HPX was two years old with 70 hours on it when I traded it. I have already gone over the 10 hour mark in just a month. I lower the tailgate in the garage and use the bed as a work bench while working in the driveway. Everytime I put the tailgate down the one Golden Retriever jumps in the bed and the other is sitting up front thinking we are going to the pond for a swim. Break time.
I think competition is really making for some good improvements in these utility vehicles.
Craig
/ I changed my mind #3
I've been a diesel fan for years, and when Iread posts about gas VS diesel, I know in my heart what disel do and how thwy do it, that's why I swear by them.
In head to head comparsions you have to figure what the needs are, if it's speed go gas, if it's power, torque, longevity, and most important, that great diesel smell...then you gotta go diesel.
/ I changed my mind #4
i test drove a xuv the other day and i didn't see where it was all that great of a machine . i like the j.d line and i will probably stick with a hpx unless the diesels have a clutch enclosure. besides that the talk on the xuv's have been bery quiet. it seems like they had a rush to get them and then they had some roblems with the brakes and the front ends rattleing and then all of a sudden things got hush! hush!. what happened to all them xuv owners. have the brake problems been fixed ?have the rattles gone away?
/ I changed my mind #5
10 hours in a month ? Shesh, I think I put that on my HPX in a week!
I've got 453 hours on mine in a little under 13 months. That's with it not being driven much in the winter too.
/ I changed my mind #6
I am almost embarassed to say we bought our HPX December '04 and we just turned 40hrs on it this month! :)
/ I changed my mind
Tommy,
I found my original Gator to be a little "rattley" but this seems to not be the case with the new one. Tight as a drum on this machine, so I suspect they made a running improvement. The diesel is interesting, it is louder at idle but I think quieter when at throttle. It definitely has more mid range power. I do think JD made a great improvement with the XUV over the HPX but we are reaching a point of diminishing returns. The HPX is a good machine, the XUV is better, but not a bunch better. Just like if Polaris came out with a Ranger 800 XPP. It might go 55 mph and have 45 hp, not 40, but would the performance difference be that great at that point. Same in my mind with the JD.
John M
/ I changed my mind
Tommy,
No, unfortunately they have not. My understanding is the diesel engine is too large to accomodate a clutch enclosure around with the frame structure. This is a problem to me, but not one that affects me. I do operate in some mud, but not much, so the lack of one is not harmful in my case.
John M
/ I changed my mind #10
I had both a 05 HPX and a 06 HPX. There was a vast improvement between the two. I now have traded for the gas XUV. I like the machine. The brakes were a little spongy when new but so were the others. After about 10 hours they will feel like power brakes.
The only thing I do like better about the 06 HPX over the XUV is the sound. The HPX was a lot quieter from the engine noise to the power train. However, the ride on the XUV more than makes up for it. The XUV is better starting, has more acceleration, easier steering, easier to get in at out of (a little taller), and has a power reserve at top end (you can hear it accelerate when going up a hill even at full throttle which makes me feel there is some uptapped speed there).
Again, the only complaint is the noise. It is not unbearable and still quieter that the Polaris Ranger or Yamaha Rhino but noisier than the HPX. It does have a bit of a rattle but I do not see where it effects performance. As a matter of fact, I cannot even tell where the noise is coming from. Some say the front end makes noise but to me it seems to be coming from the center rear near the engine mounts. I can also tell a bit of a vibration at top end, especially on a paved road.
/ I changed my mind #12
around here i use my hpx rather than my car to go up and down the street. it's easier on gas and the a/c vent really blows good.lol mines an 04 and i have 508 hours on it. man you gotta put some ridin time on that thing!!!
/ I changed my mind #14
Kahuna said:
However, the ride on the XUV more than makes up for it. The XUV is better starting, has more acceleration, easier steering, easier to get in at out of (a little taller), and has a power reserve at top end (you can hear it accelerate when going up a hill even at full throttle which makes me feel there is some uptapped speed there)..
Agreed
The ride speed and overall drivability of the xuv is excellent.
I like the diesel but chose the gas because of the enclosure.
This is my 3rd gator and they are getting lots better. My 06 hpx rode like a log wagon compared to the xuv.
This is by far the best gator to date.
I also have an 06 Yamaha Rhino, the xuv out performs the rhino in mud and in off camber situations~!
TOMMYHPX4X4 said:
i found this video these guys are havin fun but i find it hard to believe the xuv can'y pull that mower.
That's not a mower. That's a compact tractor. I would expect it to pull about any utv on asphalt or hard pack.
It has the same engine as the 850D. It's a 3 cylinder yanmar diesel with a real low crawl gear. Excellent little tractors.
You can add a bucket, back hoe, full cab enclosure, belly mower and much more~!
/ I changed my mind #15
yea but just on the weight and the tire grip it should have pulled that mower.it has to have the weight advantage over that mower they had to have that thing anchored in the ground .
/ I changed my mind
I have seen this video, the JD one, and have had both machines. There are some things to keep in mind. The 595 is AMAZINGLY stout. I have told my fellow posters seemingly a million times on the JD forum that the 595 is among the strongest small tractors ever made. Mine pulled a stuck UPS truck out of a ditch on my driveway and would climb a tree. There is no trickery in this video. I believe the tractor pulled this well. The other thing to keep in mind is that the Gator has stock tires. I have the 27" ITP mudlites on mine and a smaller tire does not take advantage of the torque these small diesels produce. With the right tire, the XUV diesel is formidible. Interestingly, when ballasted the 595 weighes close to the XUV diesel. I believe operating weight for the XUV is 1532# and for a ballasted 595 (748 now) is 1482# with loaded tires and wheel weights.
John M
/ I changed my mind #17
John M
It also appears the 595 had turf tires. The hydrostatic drive on the tractor is much stouter than the belt drive on the gator. Weight them both down with a half ton and see who pulls who on hardpack. :)
Comparing that to a mower is like comparing a Hummer to Jeep. It's not a mower. Watch this video and maybe you can tell the difference. No mower can do that. Tommy I thought you knew John Deere?Your a Murray man with a JD hat :p
/ I changed my mind #20
TOMMYHPX4X4 said:
the one with the front end loader looks bigger. the one in the video with the xuv looks small.
Same machine. Camera angle makes it appear small. They also have turf tires on. The one in the video is my brother. I've drove that little machine and it is powerful for the size~!
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2011 John Deere 1200H Bunker Rake (A66734)
2011 John Deere...
2023 Tesla Model 3 Sedan (A66738)
2023 Tesla Model 3...
Unused 2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
2025 Auger with Bits Mini Skid Steer Attachment (A66734)
2025 Auger with...
19020SFL (A64553)
19020SFL (A64553)
